Fast 90/90 Results On Bolt on Car
Got to test out the FAST 90/90 on my bolt on 99 SS this past week in 1/8 only.
I still have not got the car tuned, this may be some of my problem.
Last time out at the same track my mods were
Hooker Super Comp Longtubes
Hookey OR Y Pipe
Hooker Catback
SLP Lid w/ ram air
On stock LS1 intake, 3.23s and Chrome Zr1s
Went 8.2 @ 88mph with a 2.0 60'
Same mods, Same track, the only difference this time out was
Fast 90 intake, 90mm Nick Williams throttle body, SLP 85mm MAF, Front Swaybar Delete and Skinny Draglite fronts, still on the same rear tires.
The best I could get was 8.41 @ 87 with a 1.99 60'.
The car is running rich, you can smell it through the exhuast. It really needs a dynotune bad.
Anyways here is a pic from that day
Hookey OR Y Pipe
Hooker Catback
SLP Lid w/ ram air
Im hoping the tune will at least get me back where I was, then I will work my way down. I am wanting to make a 7.99 1/8 pass with just bolt ons, which shouldnt be too hard. After the 7.99 pass a converter will go in.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Agreed the tune likely needs some work, even without knowing the weather condition differences between the runs. The lack of mph and your mention of rich is the deciding factor.
Derek
Derek
IMO, this thread is a letdown! All you're saying is on an untuned bolt-on car, a FAST will not help. Your tune was already not spot on since your header install, and the intake swap most likely made it worse. I was hoping for a true before/after comparo on a more level playing field I guess.
Or they may have been worse. It's hard to say what mod did what to the AFR. It may be perfect now where it was off before, but you just never know without actually knowing. Smelling rich at idle or part throttle means nothing when talking about WOT passes. My AFR with a FAST swap was barely off at all. It was actually a tad bit leaner which may have made it faster untuned, but my tune was spot on before the FAST as well and all I changed was the FAST
Haha yea you called it Jon, it slowed my car down. I couldn't pass up the deal I got on it though. I do have some pre 90/90 dyno numbers I will post results on that also after a tune
Even with a stock stall I would think you should be able to pull off a 7 sec at piedmont? My bolt-on 6spd ran 7.99 @ 92mph with stock clutch, 3.42 gears, and eagle F1's. After I changed the cam I went 7.79 @94 with the same set up and stock tune.
My point is Piedmont is known for how good it hooks. I haven't been to a track that hooks like piedmont. That's all I was trying to say. As far as my time it really doesn't matter if anyone believes it or not. They can ask anyone around Burlington about a SOM SS.
