Fastest stock bottom end 6-speed?
How fast is the fastest stock bottom end 6-speed f-body? I just went 10.20@134 with my heads/cam car on 200 shot, six speeds inc built t-56. might have a bit left in it. tryin to dip into the 9's. anyone with a legit stock motor with only heads/cam power adder ever go 9's?
my bottle pressure was unkown. I sprayed 175 on my bottle (1050psi) 3 passes went 10.30's. jetted it up to 200 shot. .078 jet. then borrowed a full bottle with no gauge and heated it a little bit. no idea on bottle psi. it then went 1 tenth faster to a 10.20. i see the car goin 10.0's. i got a feeling the car on the 6-speed list that went 9.90 or so isnt even a stock motor. its 346ci with forged internals. I bought my car almost new and it really only has heads/cam nitrous.
Thats a decent time but I think the mph is on the low side for a 200 shot if you are spraying out the hole. I'm sure there has been plenty of stock bottom end cars that have run low 10s
I wasnt talking about the list, there are quite a few cars not on it or updated... I went 10.95 2years ago, and my times werent updated, then went 10.60 but why bother even posting it, if they dont update? Do you consider rod bolts an issue? If not i know for a fact there are a couple 10.1 cars.
ya spray 1 stage right out the gate. 1.40 60ft. i think the bottle pressure was low to begin with and then dropped off quickly. trap on 175 shot was 134 and the trap on 200 was also 134 but yet the et was faster. sprayin the last pass with no pressure gauge was just a bad idea. we have no idea what the pressure was to even base anything off of. not sure why it trapped so low. maybe it finally lost all the compression on a few cylinders. lol. put it right on the trailer and never looked at it. who knows.
Sounds like bottle pressure teetered off after the first run. She deff has lower 10's / high 9's in her if she holds together. RobZ from anger management's record is all motor...not sure what the 6spd/stock bottom end record is...There's a lot of variables. Just the LSX motor? In what body? I'm pretty sure I just read a GMHTP that had a 200 shot stock car running well into the 9's iirc. Has a silver Z28 on the front. Nevertheless, good runs and she has more in her.
i'm talking stock bottom end ls1 motored f-body car with a 6-speed. i personally have only seen one go as fast as me. I was just lookin to see if some members here have went 9's. I wouldn't mind pushing now to try and make some sort of a record if i'm that close you know.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
