m/t radials work well on transbrake and heavy street car!
Old 11-29-2006, 01:51 PM
  #61
gator's 99TA's Avatar
JL i am not sure why leaving at 6K rpm is a good thing. sounds like your converter is too loose
Old 11-29-2006, 01:53 PM
  #62
TN94Z's Avatar
Well ,this post talked me into it. I just got off the phone from ordering the MTs DRs. I got the 325/50/15s. Now I need to get me some 10" wheels and i will be set for next year.
Old 11-29-2006, 01:54 PM
  #63
Race your car!
JL ws-6's Avatar
motor made power to 7400.... it might be too loose I dunno... it was a starting point that will be changed by springtime... I don't think it would like a nitrous hit the way it is.. probably blow right thru it.
  #64
TN94Z's Avatar
Well, I say that but I will need to get me a 12 bolt before leaving off the brake. Guess I will be running footbrake until that happens.
Old 11-29-2006, 01:59 PM
  #65
aliwantsnss's Avatar
Originally Posted by STL2SLO
My car is HEAVY, its full wieght, and cam only, N/A. The best short time I have got was a 1.66. The car just bogs through first gear, but it still pulls the front up about a foot.
My car is 3450ish, and Im not happy with the high 1.5x its pulling. Both wheels come up, but not a foot! I think I need to see more results.... I need 1.4s!
Old 11-29-2006, 02:23 PM
  #66
Race your car!
JL ws-6's Avatar
I'm not happy with the 1.54 to 1.52 that I was doing either with the qtp's... hence my search for more traction as well!
Old 11-29-2006, 03:04 PM
  #67
STL2SLO's Avatar
I bet my car is 36something with me in it.. I didnt say that I was happy with the sixty-foot time, but am happy with the tires. The tires arent whats holding me back, its the weight. I need some 1.4s too!
Old 11-29-2006, 03:43 PM
  #68
Race your car!
JL ws-6's Avatar
hell I want 1.3x's..... once the nitrous is on
Old 11-29-2006, 08:08 PM
  #69
my car on the 1.39 60' didnt even wheelie 12" probably more like 6-8"
on my mid to high 1.4 60' i drug the front wheels.
Old 11-30-2006, 04:54 AM
  #70
Race your car!
JL ws-6's Avatar
too bad you're in florida... I'd be swinging by and taking a look at the setup in that thing... youv'e got it working really well.
Old 12-04-2006, 06:43 PM
  #71
Got Me SOM's Avatar
wow what's your suspension setup besides the narrowed rear and big meats? do you think a lot of that is attributable to running the narrowed rear and big tire combo?
Old 12-04-2006, 08:35 PM
  #72
it has nothing to do with the rear being narrowed. that was just for looks. not performance.
the combination of great tire, good track (though still a test and tune night), good converter, and decent combo of suspension parts makes it work.
i am on stock front shocks, cheapy CE rears, and teh front of the car is slammed (see pix). nothing special about my suspension at ALL.
Old 12-04-2006, 08:54 PM
  #73
choppin-suey's Avatar
my fat *** car (3680)cuts mid 1.4's off the brake pulling the tires over a foot with the 325 m/t and the 325 hoosier radials but im with you I have nothing special, I have all polly mount stuff on the car.
Old 01-07-2007, 10:10 PM
  #74
GTA91's Avatar
I've only gone a 1.58 60' on a 325/50 MT DR so far... my car weighs about 3500 raceweight, 402ci, T56, moser 9" with 4.11's. The 1.58 was with a shitty posi and slipping clutch. It sounded like a 5000 stall leaving the line. That was also with stock springs and shitty KYB shocks/struts. I just put a textralia clutch in the car along with a Chris Alston tq arm. We'll see how it does when the tracks open. I'm hoping for low 1.5's or high 1.4's on this tire and a T56!
Old 01-17-2007, 09:08 AM
  #75
PewterZ28's Avatar
Will the 325s work on a 15 x 8.5 wheel? Also, are tubes recommended?
Old 01-17-2007, 09:24 AM
  #76
vmax1500's Avatar
No to both...
Old 01-17-2007, 09:56 AM
  #77
Bryan @ Speed Inc.'s Avatar
i think the minimum rim width for that tire is 10"
Old 01-17-2007, 12:10 PM
  #78
DONT DARE put them on a narrow rim. these are 13.5" sidewall tires. 10" wide is the minimum width. they do work well on 10" wide though.
no to tubes, they are stiff sided radials
Old 01-17-2007, 01:10 PM
  #79
GrannySShifting's Avatar
No dont run 8 inch wheels with that tire. You dont need a 10 inch or that wide a tire to cut a 1.4 though, Im doing it on a stick car, you cna at least equal your current best throwing them on you current rims
Old 01-17-2007, 02:05 PM
  #80
PewterZ28's Avatar
Someone mentioned screwing the tires to the rims, I thought you had to use tubes if you were going to do that? Guess not.
I wonder if the 275/60 will work better than my 27x11.5x15 QTPs. I'll need a 28" tire anyway this year.
Quick Reply: m/t radials work well on transbrake and heavy street car!
