started the day with 3 pedals...finished with 2 pedals
#62
heres an option...
http://tricktitanium.infosaic70.com/Bell%20Housing.htm
It says they can pretty much make anything to your specs, can't imagine it being cheap though. I know local pro-mod guys use there stuff, so it can't hurt to ask.
#64
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
joeslter,
thanks so much!!!! they are right in my backyard and down the street from stenod. too cool! i didn't realize they made them!
#66
1 Post
well, everything is hurt...trans, clutch/bell housing/ and motor, headers, rad, ft. right tire, wire harness, floor at hump is ripped apart. i will be lucky to have it all back together for april 19th.
you are right someone was looking out for me!
#68
1 Post
what i really need to do is win the f'n lottery to piece humpty back together again. I have never damaged it this bad pefore.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#70
1 Post
if it is structurally and dimensionally the same as an uncracked on i could most definitely use it. please keep me posted. I would be happy to pay for any associated shipping costs to borrow it as a mock up.
thank you!!!!
#72
1 Post
ringlands..... no load on the motor with n2o, it leads to a slight reduction in compression. nothing catastrophic but alas time to change some soldiers. on the upside everytime i tear it down, my friend/builder seems to pull a few more hp out of this stout little 23 deg. combo ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
won't know how bad the trans is hurt, until it is apart.
harness can be fixed but it will take some time to figure it out. i have an awesome friend who is an electrical guru, and will go thru that and test it for me.
need to drop rad off to get it fixed, 2 holes in it now, pick up a new front skinny, fix both headers, crushed primaries, the list goes on and on.
but the b/h for a mock up would be great! i can give it to the guys at trick to make an SFI approved piece as required.
thanks Ellis!
thanks Ellis!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#73
Taner.....get me the headers....we'll get you fixed up. On a more serious note......pull some weight out of that puppy.....how much do you REALLY drive it on the street anymore. It'll save you a ton of money in breakage in the long run. Glad your injuries aren't more serious.
#74
1 Post
lol! thanks Rob! i will get them to you later this week. aside from the transmission keeping me sidelined almost all of this summer i do drive it! this year was screwed because of it. last year it was the opti that kept me sidelined for a bit, and then upgrading linings on the clutch. i will call randy for your number in the event i don't have it. i won't gut the car. the car is inherently heavy, if i cut the roll cage out i would be a fair bit lighter, lol!!!
#78
1 Post
joelster,
i called trick, they only make them in the shape of a can, not tapered to clear the trans tunnel, oh well. it was worth a call.
thanks coach!
rob,
yeah i guess you could say i am stubborn. it will all pan out.
thanks coach!
rob,
#79
Hey Taner....how bad is the tunnel? If it needs some serious refabrication due to all the damage, couldn't you reshape it to fit a bellhousing that is currently available? Or is there more to it than that.
#80
1 Post
the tunnel is not pretty but to reshape it would be more than i want to get into. i just have to drop the starter and pull the other header out and motor is ready to pull. i pulled half a distributor out of the intake tonight! doh!
