PAF chute / release system installed.
How do you guys like my release handle location?
I'm very happy with the fit and finish. Thanks a lot Tyson.
basically the pivot for the release handle is welded to the top of the ebrake pivot bracket, and the cable support is welded to the tunnel just behind it. some of the console underside had to be modified to clear, but nothing visible from topside.
there is one track here that has a very short stopping distance, so in some cases its good for precaution. a chute should only be secondary means of stopping, IMO.
yea black woulda been good too. it's in to stay for a while.. not getting back into that junk.
b&m quicksilver shifter
as i said this chute mount is removable with one bolt and disappears completely behind the license plate.
the burkhart is a very similar design to what you have. bolts to the stock bumper support, easily removed.
it just has a nice bend in the tubing to curve around the bumper rather than just go strait up.
cosmetic more than anything.
the burkhart unit also has a sleeve for the shute cable to ride in.
either one gets the job done, im not ******* your mount.
this one is bent around the bumper, it does not go straight up. it also has a sleeve for the cable to ride in.
full size pics here, maybe they will help
http://fastrides.com/photos/mm/image.../original.aspx
