Drag Racing Tech
The Turbo Ta Build Thread
Old Apr 25, 2010 | 07:29 PM
Broke EF's Avatar
I just so happen to have a couple more pics of that front end from this weekend.
Sean
Old Apr 26, 2010 | 08:37 PM
Broke EF's Avatar
This came today
Sean
Old Apr 27, 2010 | 06:00 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Oooh, I really like that upper shock mounting setup.
Old May 1, 2010 | 09:14 PM
Broke EF's Avatar
Alright kiddies, this week sees some visible progress finally! Ill just skip to the pictures this time around!
Got the motor back to the house and un-crated (They did an awesome job crating this thing up, as noted by the cradle)
We had to muscle it onto the stand since we don't have a cherry picker, but it all worked out just fine.
Not to exciting, but here is the bottom side
Next on my list of **** to do was getting rid of the clutch pedal. Here is what I started with
Took it apart
Found the two welds that attached the clutch part of the assembly to the rest of what actually bolts into the car
Ground them out
Then just pooped it off and smoothed it all out
And there you have it, no more clutch pedal and it still bolts to the car the same way so no strength has been lost. I will have to make a piece for the brake pedal to hinge on though.
Finally drilled the holes for the shifter mount (on the car side) so we tossed it in there to check it out. Don't mind the baller bolts
While I was doing that, Chris was busy pulling out the rear end so he can take it to get it shortened next week.
So empty
He also cleaned the **** out of the engine bay, and the interior. Then he painted all the bare metal inside to get it all ready for carpet. I wont bother putting pictures of this stuff up. But I will put this one up just because
Saturday morning, and we are ready for carpet! Here is Chris smoothing it out before we got started.
Getting started
Bolted in the shifter for the first time.
It is harder than you think...
This is about as far as the carpet got this weekend, I didn't want to try and tackle the rear bars all alone.
Other than what you see in the pics we finally wrapped up all the small work under the car. All thats left is to clean it which Chris will get done during the week. Next weekend we will start getting the motor together so we can at least get the measurement for push rods. As I said before the rear end is going to Midwest Chassis to get shortened up 3" per side as well. And maybe we can get the carpet finished up so the interior plastics can go back in. Thanks for looking!
Sean
Old May 2, 2010 | 04:06 PM
OWN3D BY MY PROF!
That seems like a lot of work for simply removing the clutch pedal. I had a set of automatic pedals you could of had if you paid the shipping. No one ever wanted them so I threw them away a couple days ago.
Those allen wrench bolts are pretty baller. I really like those carbon fiber shifters. I may end up getting one for my 93 at some point. I just like the OEM stealthy look.
Old May 2, 2010 | 04:50 PM
Broke EF's Avatar
It wasnt that much work so far, but I havent made the spacer yet. We didnt want to spend the money/time trying to find a set of automatic pedals. Plus the brake pedal is smaller on the manulal, so its lighter this way
Your jealous of the allen key bolts, I can tell. The shifter is sweet Chris had a hard time finding one. They discontinued the all carbon one right before we were getting ready to order one. Luckily he found a place that had one sitting on a shelf, I think it was from 2004 or so.
Sean
Old May 2, 2010 | 07:12 PM
RS_SS69's Avatar
Awesome build, If you dont mind me asking what did that whole front kit cost or what are they going to charge?
Old May 2, 2010 | 08:02 PM
Sideways240sx's Avatar
I would say to talk to eric about the price. He is a sponser on here, midwest chassis. If you need contact info let me know.
Thanks, chris
Old May 2, 2010 | 08:46 PM
RS_SS69's Avatar
Thanks, chris
Cool ill shoot him a call tomorrow.
Old May 9, 2010 | 05:53 PM
Broke EF's Avatar
Here we are, week 4 (I think) and shes moving along. I would say that this weekend was full of ups and downs. The plan for this weekend was somewhat simple, finish the carpet (and get the plastics in), assemble the motor as far as we could, and get the rear end narrowed. I guess we will start with the carpet/interior then.
Here is the carpet finished, and the plastics back in
Next up is the brake pedal, if you remember last week I had cut off the clutch pedal. Well that caused one small issue, the bolt that held in the clutch pedal also held in the brake pedal. No big deal, chopped it down, bored a hole and wa-lah a perfect fit spacer!
Toss in a grade 8 bolt, and its all set.
I still have to drill the pedal for the manual master, but then it can go back in the car (next weekend).
Next we will travel down to Midwest Chassis where Eric narrowed the rear end 3" each side. We left to get some food so we missed the cutting part, BUT we came back in time for safety 101
Here is the chunk he chopped off
The new end
Welding it up
All done and back home
Close up of the welds
We have to send the axles back to Moser to get narrowed, so no pictures of it all finished.
On to the good stuff, the motor!!! Chris had installed the heads during the week, so this is how we started out this weekend.
Put the rockers in, and marked the valves so we could measure for push rod length
Thats when problem #1 came up. We bent the push rod checker and it got wedged in the motor, so we had to pull the head off. At least I was able to take some pictures then
Nice crosshatching
Artsy motor shot
Artsy valve spring shot
Artsy head shot
Chamber pic
OK now that that is over with, head back on and torqued, and the valley cover installed
Front cover, crank pulley, and valve covers on
Water pump on, and the start of problem #2
Because of the way the turbo kit is built (using forward facing truck manifolds) the alternator had to be located on the top side of the motor. Since that is all we have left to run a belt to, the water pump is directly in the way. So it came right back off and boxed back up. We are not 100% set on a solution yet, but we will get it figured out.
Moving on, here is a picture of the motor as we left it for the weekend.
Thats all for this installment, as always thanks for looking!
Sean
Old May 9, 2010 | 06:35 PM
Eddie Krawiec's Avatar
Thanks, chris
I will be using Eric's stuff as well. He did a nice job on it and it look's very good in the car. I would tell anyone looking to a front K-Member for drag racing should check it out.
Good luck with the build. Ed
Old May 9, 2010 | 07:29 PM
  #32
Broke EF's Avatar
Yeah, Eric does great work we are always happy with his parts!
Thanks Eddie! BTW I liked the YB shoutout last week
Sean
Old May 9, 2010 | 07:37 PM
  #33
Sean
Thanks, I got a ton of e-mails and PM's for doing it. They are a bunch of crazy SOB's over their. I guess thats why I hang out their also. Their is always something or someone putting someone else on the chip. LOL.
Old May 10, 2010 | 07:08 PM
  #34
frcefed98's Avatar
Looking good guys, the car has come along way
Old May 11, 2010 | 01:52 PM
  #35
camscam02's Avatar
what carpet is that and where did you get it? It looks good.
Old May 11, 2010 | 04:53 PM
  #36
Yes it has. Thank you for all of your help during the turbo build!
Thanks, Chris
Old May 11, 2010 | 04:55 PM
  #37
Carpet is Ozite. it is a pain. It comes 80" wide, and how ever long you order it, i got 5 yrds.
Everyone on here buys it from
http://www.yourautotrim.com/black7.html
Thanks, Chris
Old May 11, 2010 | 05:41 PM
  #38
Phil99vette's Avatar
7 Second Club
Looks good, I'd look into a set of strange axles before too long. Moser doesn't heat treat their axles after they cut them which makes them weak.
Old May 11, 2010 | 08:08 PM
  #39
Broke EF's Avatar
Thanks for the tip Phil, we will keep it in mind.
Sean
Old May 11, 2010 | 08:45 PM
  #40
BAKED's Avatar
Looks good!
You can mount that alt down where the A/C compressor went and mount the tensioner up on top of the drivers side if you are creative enough. I recently made the bracketry for a friend that has a truck manifold kit.
