ASR, BRAKE, and ABS lights came on after rear end swap?!?
I recently installed a new MWC Fab9 rear end and drove it fine with no problems for a couple days. Well when I took the car out for a little drive today the ASR, BRAKE, and ABS lights all came on. So I pulled over to the nearest gas station and looked under the car and the harness is plugged into each abs sensor and into the plug on the car. I have no clue as to what it could be...
Has anybody else had this problem or know what it could be? Sorry if this is in the wrong section.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I had a similar problem recently. I put the car on jackstands and decided to try and follow all of the abs module wires after reading a similar thread on this site. Found that the wires had been burnt in half where the exhaust goes over the rear axle. Got a new piece of wire to bridge the burnt wires, soldered(?), rerouted and voila - fixed. Hope this helps
Ok yeah I will deff put it up on jackstands and double check the wires and check if something like that happened. The new rear end I put in has a 3:89 gear. I didnt get a new tune yet because I am still hooking up my nitrous. Yeah I did put some 28" tall tires on the back as well. Would the gear and bigger tire make it do that for some reason?
While I was doing research for this very problem I came across the fact that 28"s cause these lights to come on as well. That is what I would guess your problem is since that is what your running. Evidently the diameter difference of the front and rear tires confuses the computer as the abs system was calibrated for matching rpms from all four tires and deactivates. With the stock tires back on the lights should go away.
