Remote mount electric water pump questions.
OK. So i bought the meizere drag race pump. With it bolted up, we realized that the belt will not clear it. the problem is my turbo kit uses truck manifolds, so i cannot have the alternator at the bottom, on either side.
I have a bracket and had the alternator on the pass head, but the belt will rub on the water pump that i had. So i am thinking of going remote mount. now the problem i see is the number of hoses. The adapter plates for the lsx give me 4 -12 total. My radiator is set up with 2 -16's on it.
Right now my best solution is to bring 2 -12 from block to a Y. I would like the Y to be 3 1"npt so i could go two -12 in, and 1 -16 out. Do -16 from Y to pump, and -16 from pump to rad. Then come out of rad with -16, and go to a Y, and 2-12 out of Y back to block.
I know i could go back to a mechanical pump. I know i could buy a 1100-1400 dollar radiator setup and make it work, and i know i could change my turbo kit so i can put the alternator back down low. I am trying to make it work with what i got.
This is a picture of what i had, and didn't work.
![](http://www.sidewayz.net/cooling/1.jpg)
I guess my last option would be the meizere electric water pump with the pulley still for the belt. I am really trying to either find an electric water pump with better fittings, or a good way to adapt 2 -12 to 1 -16
remote pump, and a make 2 or 1 dual alum tube "Y" that bolts to he block, with one fitting for feed/return. You can make the offset to clear what you need.
http://www.monstermarinestore.com/im..._eddie_co2.jpg
Just a quick question. Couldn't you sell the race pump and get the street version and make the belt work? I think it would be cheaper that buying a remote mount and all the fittings and hose to make that work. Just thinking out loud.
The water pump you are talking about is 570ish dollars, but it is an option.. The other good part about remote water pump is i can fit a bigger turbo easier.
Thanks, Chris
I would have to re modify my radiator, or get a new one.. Not a super big deal, but not sure how much of a fan i am of it, because i forsee it maybe being in the way for Ic pipe...
I do love your setup alot, and i have been looking at it, just hard for me to justify the 1400 dollars right now, when i have a new griffin rad with -16's on it.
I can do remote pump for 271, i have -16 fittings, and hose, the block adapter from meizere is like 85 bucks, so i need to adapt the 12's to a 16, get some 12 hose and 12 fittings.. I think it can be done pretty cheap, and i think ive found my solution.. I will know for sure tomorrow.
Thanks Chris
Thanks Chris
ya that looks really good chris thats what I saw before. My buddy that builds chassie cars told me he wasn't a fan on the rad. mounted pumps, for a few cars hes worked on with them. And to get a normal mounted remote pump if I go that way. I made the thread about this over the winter, has some info but I never got around to getting anything.
Just looked over at the Meziere site. I couldnt find any of the 55 GPM pumps that cheap. What part number is that? I am looking at going the same route in my third gen swap. Thanks, Mike.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I think that price (271) is for a 20gpm pump. the 55gpm units are much more expensive.
I run a remote dual outlet meziere pump (WP337). I just run a hose from the bottom of the rad to the pump inlet, then two -12 lines to my block (lower ports).
meziere makes a -12oring to -16 fitting (for their block plates) so you can run -16s from your rad to motor.
http://www.meziere.com/ps-832-800-wp12016b.aspx
Is there any reason that you couldn't reverse cool these motors? I mean most of the heat built in a motor is in the heads. Wouldn't it make sense to run the coolant through the heads first?
I only have 2 fitting on radiator, and 4 fittings from motor.
Right now i think im going to get rid of one of the -16 on rad, put 2 -12 bungs, so i have one side taken care of. then go with a -16 from rad, to pump, and then 2 -12's out of the pump back to the block.
chris
http://www.meziere.com/ps-795-763-wp116shd.aspx
That is the 42gpm pump if anyone is interested. I think i saw it on summit for 271.
Chris
Chris
