Drag Racing Tech
SS4000 vs. PT4400 come on in !
Old 06-12-2010, 01:53 PM
  #61
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
maybe the PT4400 would be best for my SI car, it only weighs 3200ish and im down on power so i dont think it would be to loose...but i only have 3.23 gears, and i dont know if its staying stock internal but it would be nice to run some low 11s w/o a cam
Old 06-12-2010, 03:06 PM
  #62
chrs1313's Avatar
Originally Posted by JonCR96Z
I know that you don't have to oblige me but you still didn't answer my question about the shift point and extensions, yet you took the time to answer everything else. What are you hiding?
And Red Alto bands have nothing to do with your 3-4 clutches. It sounds like you are saying that you have a stock trans with a red alto band.
No, I'm still in the 11.6s but it's also a 3550lbs car with my A/C all my seats and the stock 17s on it. And it always will be. Good luck on your quest for MPH
damn i answer all 99 of your 100 questions and forgot one haha you are a joke...
shift extensions were posted in another thread, here i found it enjoy man
https://ls1tech.com/forums/13308710-post178.html
my quest is 9s...
Old 06-12-2010, 03:38 PM
  #63
JonCR96Z's Avatar
my quest is 9s...
That's the same **** that you told me in the PM that you sent a while back. I was asking about the actual RPM of the shift and the extension and have about 4 times now. I really don't even give a ****, but it's like you can't comprehend the question.
You answered all of my questions that only required opinion answers but left three out that could only be answered by actual facts. The RPMs, what data logging software and the 3-4 clutches. Like I said, you act like your hiding something.
The only reason I ask is because I've have seen similar recently with an SS4000. It had a great 60', a good 1/8, not so good 1/4 but horrible MPH. All that was changed was the converter. It lost 4 mph in the 1/4 over the stock converter, where it SHOULD have at least gained 1 mph. Did about 5 runs, all nearly identical. Working on getting a fresh trans now, before I start just completely slamming the SS4000. Sometimes there are other factors at play, but I guess your results are just too detailed for something like that, huh?
And I know what you're after. Guess you didn't get my joke.
Old 06-12-2010, 04:55 PM
  #64
00blacka4's Avatar
what do you mean by lost 4 mph should have gained atleast 1mph....are you sayin that the 3 4 clutch pac was slipping or something else was wrong with the tranny or car ? j/w what point that ur making in ur previous post jon...and do u know the exact quartermile ET that was gained with the converter...thanks
Old 06-12-2010, 05:19 PM
  #65
JonCR96Z's Avatar
It's not normal (never happens) that people lose MPH with Yank converters. With the stock converter this car ran low 1.9 60's, 8.0-8.1 in the 1/8 and 12.4s@ 114 in the 1/4. After the converter it cut a 1.56 60' (Pulled the driver side stock 16), 7.5-1/8 and 12.0-@110 1/4. I can't remember the 1/8 mph right off hand but it was the same before and after. The DA was slightly worse but not enough for that kind of drop in the 1/4, especially since the 1/8 was much better.
I was logging all the trans parameters and making sure the tune (AFR and timing) was spot on during every pass, and nothing was out of place there. And the only thing that changed was the converter. This was a 90k mile completely stock trans with only computer tuning to improve shifts (that was also done before the stall). The fluid is still looks and smells fine perfect and it still drives fine other wise. And it ran within .1 all night, the only real difference in the runs was trying different launch rpms. I've talked to Yank and others about this and the general consensus is the 3-4 clutches.
You can get aftermarket 3-4 clutches but not any others (that I've seen) which tells me that for some reason the 3-4 pack needs more than others.
Old 06-12-2010, 05:26 PM
  #66
madmike9396's Avatar
Take it easy on em Jon LMFAO !!!!
Old 06-12-2010, 05:31 PM
  #67
IH8FORD's Avatar
Chris1313 is right because his car is faster. You ready to watch Chuck Liddell get his *** whipped.
Old 06-12-2010, 05:38 PM
  #68
i have to disagree with chuck getting his *** kicked sorry !!!
Old 06-12-2010, 05:40 PM
  #69
IH8FORD's Avatar
Want to put 20 on it?
Old 06-12-2010, 06:39 PM
  #70
JonCR96Z's Avatar
I want to see the jiu jitsu rematch of you vs a TH350. Everyone that I told thought it was funny that you were mounted and almost armbared by a transmission.
Old 06-12-2010, 07:00 PM
  #71
IH8FORD's Avatar
I managed an escape and the match ended up in a draw.
Old 06-12-2010, 07:07 PM
  #72
KH504's Avatar
Im in here
Old 06-12-2010, 07:15 PM
  #73
If i were to bet he would lose 4 sure thats how bad my luck is lol
Old 06-12-2010, 09:58 PM
  #74
00blacka4's Avatar
yeah maybe the guy that gained .4 and lost 4mph had a slipping 3 4 clutchpac....thats why my tranny is getting beefed up and im getting the zpac along with a bunch of other goodies put in it...hehe and i really do appriciate all your guys imput...kinda interesting so jon in ur opinion what should that car have run without the mph problem which was probly something wrong with this car from that added converter...because if i had to put money on it id say im at a 12.3 right now....some mid 11s would be nice with a converter and a tune along with my beefed tranny, 85 maf 98mm lid im adding...
Old 06-12-2010, 10:08 PM
  #75
JonCR96Z's Avatar
Based on my results with my converter as well as others (including Chris') Dropping 3.5 tenths in the 60's should easily be 7-8 tenths in the 1/4. Considering that this car was faster than I was, both on stock converters he should be faster still with a similar converter. If I had to guess what I would have thought it would run in simlar weather that he ran his best time (which was actually a 12.38), I'd say high 11.5s, low 11.6s at around 115 mph.
Old 06-13-2010, 11:25 AM
  #76
BennyB's Avatar
I have tested both on my car pt4200(not a typo) and a ss4000...with 900ft better air I ran .5mph slower with the pt4200...the 60ft was .01 better with the pt4200 on the plus side...
the pt4200 just loses too much hp up top...I should have been up at least 1mph with the better air...so the pt4200 loss me around 1.5mph...
I wanted the pt to be better but it wasn't...my vote is the ss4000 but it looks like I am in the minority, either way if you get a pt or SS they are both very good...if you do pick the pt I would make it a pt4000...
Ive raced and seen pt4000 cars with similar mods get beat by ss4000 cars... im a ss4000 car so i agree with what was stated above. They are both great converters though and you may not notice a difference at all or maybe minimal differences at the track and also mentioned the ss series converters are what... 100-200 bucks cheaper?
Old 06-13-2010, 02:57 PM
  #77
00blacka4's Avatar
i think im going with the SS4000 just for the fact its cheaper and i might be adding a cam or some more power sometime so it will let me grow...if i could see an 11.5 i would be a happy SOB ! let me tell ya...thanks for all the input.
Old 06-13-2010, 03:39 PM
  #78
Detroitmuscle's Avatar
not that this may mean anything but my car seems to trap very well for the mods and weight it trapped 121mph last year in good DA and 119.5mph in 2200 DA and my car is a pig.
Old 06-13-2010, 10:04 PM
  #79
JonCR96Z's Avatar
Just to go ahead and put this out there. I just read the thread that Chris posted the link to (his head/cam dyno thread). The car is shifting higher than it should (possible indication of some slipping, but could be anything) and he also seems to have a rebuilt stock trans with a few hard part upgrades as well as a Red Alto band (no mention of upgraded 3-4 clutches, not that they wouldn't wear out either) and the trans was checked at the end of the 2008 season.
He also mentions getting an FLT transmission at some point. I'm willing to bet that when the SS4000 goes back in, that so will a better trans. And if he does that you'll never hear the end of my **** talking. ******* NEVER!!! Unless of course it runs slower still, then I would only talk minor ****. Just saying.
Keep up the good work Chris.
And I've seen heads/cam cars with similar setups to me that I've outran. That must mean that aftermarket heads and cams aren't as good as the factory stuff. You have an SS4000, so of course you agree with someone else who has an SS4000. That's why you can't believe half of the **** you read on this forum.
You're right. It doesn't mean anything without a little more detail.
Old 06-14-2010, 12:17 AM
  #80
SLOW GTO's Avatar
Default ....
My car is a pig as well Nice trap speed!
Quick Reply: SS4000 vs. PT4400 come on in !
