My Stock Internal M6 buid thread...10's???
#243
Ideas? I'm going to recalibrate it with open air.
#244
http://www.hptuners.com/forum/showthread.php?t=9448
http://www.hptuners.com/forum/showthread.php?t=11018
https://ls1tech.com/forums/pcm-diagn...d-ls6-car.html
#245
I know they don't really recommend getting power from the cigarette lighter. I get my power from the fuse box by the driver side door. I think there is a spare spot that says ignition. I've read alot of people have issues with the LC-1's, but I have the NGK afx and I ground mine right to the steering column. I've always been able to use the full 0-5v range while testing the sensor.
#246
Na your just slow
just kidding. Yea are those mustang numbers or dynojet? Locked or unlocked? The converter is eating up a good bit..
I forget which one it was, but one of the top stock internal guys back in the day (low 11's) dynoed his car and it made 320rwhp. So it definitely isn't about being a dyno queen! Your car rides out, thats all that matters..![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#247
I did the free air calibration again, and its still screwy. I checked all my formulas and I beleive them to be correct. Logworks is reporting strange AFR as well, so I don't think it is on the hp tuners side at the moment.
Logworks read upwards of 26+ AFR at idle which doesn't make sense b/c according to my programming it should be limited to 20
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#249
what firmware does it have on it? I never had anyluck with anything other than the original.
http://www.innovatemotorsports.com/f...ead.php?t=7501
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
#250
I've heard changing firmware can brick the lc-1. I just can't decide if I suck at this that bad or if I just need to sell out of the. Lc-1 and buy a PLX or something.
I'm getting sick of this!
I can't install my new stuff if I can't tune it afterwards..
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#253
Took a break from the wideband because its been pissing me off. I might be a ricer for even thinking about this, but I spent my time wrapping my headers instead![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![](http://i12.photobucket.com/albums/a216/magnet123/73229936.jpg)
Its DEI titanium, suppose to have a higher resistance, it doesn't have to be applied wet, and doesn't need to be sprayed with ceramic coating..Every little bit helps right?
#260
Good. At least I have one persons support ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I got my EWP mostly installed today. Mechanically it is all buttoned up, but I need to run some aluminum supports strategically and button up the front end/nose.
I did hit an AC line and leak out all the compressed air in the system, although no freon came out. I'm not really sure what needs to be done here?
