Drag Racing Tech
My Stock Internal M6 buid thread...10's???
Old 12-20-2010, 06:58 PM
  #161
nocooler's Avatar
Originally Posted by Magnet
Im not even using hptuners yet, I'm just trying to get logworks to work the only things I can think of is that 1. my wiring/soldering is bad (pretty possible) 2. My calibration in logworks is off (likely) 3. the schematic is wrong (doubtful) 4. LC-1 is broken (I sure hope not)
I used these instructions - since you don't have the gauge, ignore that part of the wiring and calibration.
Long *** link
Old 12-23-2010, 07:26 PM
  #162
Magnet's Avatar
Long *** link
Thanks for the link.. I got pissed and stopped messing with it though lol.. Maybe tonight. I'm hoping I can pick some more power up from the tune.. It hasn't ever had its AFR looked at or been on a dyno...
Here are my slips from the other night BTW
Old 12-30-2010, 09:23 PM
  #163
Magnet's Avatar
The car lost 32lbs off the nose today
Old 01-01-2011, 02:54 PM
  #164
Magnet's Avatar
Well, good news... I have an electric water pump on the way
This is how I dropped those 32lbs!
Old 01-01-2011, 04:19 PM
  #165
Magnet's Avatar
I want to try and max out my motor power wise stock internal, here are some things on my mind, any thoughts?
- EWP (on its way)
- Switching to 1 7/8ths headers
- Wrapping the new headers
- Bigger lid
- FAST 90/90 (or 92 etc)
- Full dyno tune
The bad about all this though, is that its A LOT of money, and it could net me ZERO power
Old 01-01-2011, 09:02 PM
  #166
Grr
Grr's Avatar
It could, selling what you have would negate alot of the cost though. And you WILL gain power, how much is a crap shoot. I would start with that list, if you go to a bigger motor in the future its all stuff you should have anyway
Old 01-01-2011, 09:08 PM
  #167
Magnet's Avatar
I agree.. I've been kicking around the numbers and selling my stuff like you said I wouldn't be in anything too bad..
With all of that stuff I would hope to pick up at least 10-20hp though..
I really need to figure out my Wideband!!!!!
Old 01-01-2011, 09:15 PM
  #168
Grr
Grr's Avatar
just wire it in to regular power and ground, i wouldnt trust using that O2 wiring myself, those things actually draw quite a bit of power
Old 01-01-2011, 10:41 PM
  #169
Magnet's Avatar
I might just have to.. I really wanted to be able to move it between cars, but it's not doing anything right now the way it is..
Old 01-01-2011, 11:19 PM
  #170
Grr
Grr's Avatar
thats a pretty sweet setup, am i correct by gathering you are running a stock tune as well? Or is it a mail order or what
Old 01-01-2011, 11:25 PM
  #171
Magnet's Avatar
I have HP tuners and have messed with it some but without a wideband i obviously can't really do anything. I leaned it out slightly though as a few guys advise to do bc they come rich from the factory..
Old 01-06-2011, 03:59 PM
  #172
Magnet's Avatar
I have a bunch of goodies on their way
Old 01-10-2011, 11:08 AM
  #173
Magnet's Avatar
Going back to the track this thursday with the k-member in, and MT front runners instead of 165 metric tires..
Old 01-10-2011, 02:31 PM
  #174
studderin's Avatar
good luck!
that 32 drop was the Kmember and tires?
Old 01-10-2011, 04:40 PM
  #175
Magnet's Avatar
Originally Posted by studderin
good luck!
I dropped the 32# from the k-member alone.
Worked on the car more today, will post some pics of stuff later tonight.
Old 01-10-2011, 09:59 PM
  #176
Magnet's Avatar
Worked on the car more today. Took out the following:
Brace above reared mounted to the body: 2.64#
Fog lights: 1.78#
Sound deadener under center counsel: 2.78#
Ebrake and cables (did not remove anything from axels): 6.93#
Total lost today: 14.13#
Removed since I last raced:
K-member: 32#
Changed to MT front runners: 10# (rotational )
Total since I raced: 56.13#
Also got some goodies in the mail today
Old 01-11-2011, 07:58 AM
  #177
Golf&GM's Avatar
Sorry if I missed it earlier but what are you expecting your race weight to be now?
Old 01-11-2011, 08:21 AM
  #178
Magnet's Avatar
My best guess is around 3090-3100 with the 56# I just removed. I really need to get it on a scale in race trim, but test and tune never has it open.
I should be able to pull around 50-70# more out of it, without touching the doors, glass, airbags/ dash, brakes, AC or heat...
EDIT: that's also with stock weight rear rims and tires, so you could add whatever weight savings 28in ET drags on a 15in Prostar or similar would be to the 50-70#.
Old 01-11-2011, 11:00 AM
  #179
Golf&GM's Avatar
How's the road noise with the lightweight carpet? That 60' is killing you but that's a pretty wicked trap speed.
Old 01-11-2011, 11:31 AM
  #180
Magnet's Avatar
You can definitely hear the road more, but it doesn't bother me one bit... What is awful however are my rod ends. I bought some Polly ends to put on soon hopefully.
What's killing me is my stock rearend. The 60' is only bad bc I take off like a grandma..
Unless I break, the trap speed should get better this Thursday, with the 70-80 more pounds I'll have out of it, plus the weather is going to be amazing!
Quick Reply: My Stock Internal M6 buid thread...10's???
