Steel vs Chromoly Cage
Formerly 4mulaJoe
I'd like to hear some opinions on Steel Cages vs Chromoly. I know the obvious reason to go with chromoly is to save weight. Does anyone know the actual weight deifference between chromoly and mild steel? I could not find it doing a google search. Are there any other advantages to doing chromoly? I'm tempted to spend the extra cash on a good welder, buy a cage from jegs, and do the install myself. Opinions?
Chromoly is 30% lighter than mild steel
so let's say you have a 100 lb mild steel cage
you would have the same cage in chromoly it would be 70 lbs
other plusses
chromoly can only be tig welded(looks better)
you won't regret doing chromoly do it right first
other plusses
for a roll cage your looking at about 50-60 pounds difference.. then obviously you have take take into account the price difference between them. I have a supra and the main hoop for it is mildsteel(weighs 23pounds) my fathers chromoly main hoop in his firebird was about 14 pounds.. now thats just the main hoop, so now think about all the bars that are also going in the car and you' ll get up to 50-60 pounds difference between them quick... also, a mild steel cage can be tig welded if you wanted the welds to look better. jason.g
i just weighed my roll bar(not installed yet,lol) 6 point mild steel 85 pounds.. i'll see what the differnece is between the mildsteel bars and chromoly bars tommorow.. i'm gonna put the mildsteel hoop in my car, but make all the other bars out of chromoly.. i don't ever plan on putting a roll cage in the car so this will be perfectly legal and lighter then going with the mildsteel through out.. jason.g
Originally Posted by bspz28
mine 5 point chromoly bar was 52 pounds . and that was with the plates also
I am going through the same decision: These are the wolfe prices for 10pt (jig Notched)
Mild Steel - $710.00 - 135lbs (I can weld in myself)
4130 CM - $924 - 95lbs (They charge around $1000.00 to install if I completly gut out my car)
My thought process is if 40lbs is worth $1300.00, and also if I decide to weld anything to the cage (window net, seat support, etc) who will I bring it to since I dont have a tig welder, if it is mild steel I could do it myself.
Formerly 4mulaJoe
Some of us just don't have deep enough pockets to spend as much on a cage as we did on our motors....
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
The only reason to do a 6 point steel would be if you knew you were going to need a 10 of 14 point cage in a year or two and you just needed to get by until then. Otherwise you'll probably going to find yourself wanting to free up that 20-30lbs some day. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Rick
Rick
Originally Posted by SMOKIN01TA
how about some input on the bolt in version 6 pt. still lighter that steel right.
but i assume you loose some of the stiffnes right.
if its a legal kit [once back bars are welded ] it should still be made out of same material so there would be no wieght savings
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Originally Posted by NRC-Motorsports
if its a legal kit [once back bars are welded ] it should still be made out of same material so there would be no wieght savings ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
