best 60ft with a 4l60E
4Ljunkie transmissions are just that, junk. good if you're under the 400 rwhp mark, anything more then that you're on borrowed time, period. I've heard so many claims of this level of power and that, but at the end of the day... none of them last. Sure they "might" make it down the track for a day... but I don't think they do that for more then 1 or 2 before having to come out of the car.
That to me, would get real old. Mine as well leave a T56 in the car and just enjoy breaking that on a rather regular basis.
I have a FLT unit and street drive my car often and see good track time in the 1.40 range NA and low 1.3's N20 without issues. I have many other cars doing it time and time again with FLT 60's as well.
many of them full weight or better street cars
1.32 60ft @ 3400 #'s 396ci 200 shot on 275/60/15 Radials / my car 97 Z/28
1.42 60ft @ 3800 #'s going 10.4@130 H/C w/ D1SC on 17" Radials / 00 SS : customer not on forum
1.37 60ft @ 3800 + lbs 9.62@139 H/C w/ F1A on 275/60/15 Radials / smokenz16 / Z/28
1.44 60ft @ 3600 #'s 10.4@130 H/C 150 shot on 275/60/15 Radials / my dad's 01 Z/28
1.32 60ft @ 3600+ #'s 9.6@142 416ci 175ish shot on 275/60/15 Radials / Z8's 01 SS
1.29 60ft @ 3300ish #'s bottom 10's H/C setup / Chrs1313
low 1.5's @ 3600ish #'s 10.4@130ish 6.0, cam and TT / 70 Chevelle / INTMD8
these are right off the top of my head and again have many street miles as well as track passes + I know there are many more of my customer as well as forum members
I hate when people knock the 60E because they have been to the wrong builder and seen them fail.
Take care.
I too would like to hear about this engine. With that kind of power you should already be way in the 9's maybe even 8's if that is FWHP thats still 570 or better to the rear wheels. I am no where near that NA and I can go low 10's with out a problem on a good track with what I would call not the best air conditions. Is this a different engine than you posted in the dissappointed 408 thread? I see you are in So IN. where do you race at?
Last edited by Doughboy692; Nov 21, 2010 at 12:25 AM. Reason: added 2 questions to the end
I'll have a 2900 lb car, with enough power to run well into the 8 second zone. If you think your 4l60 will hold up, send one to me and I'll put it in my car, and give 100% feedback, GOOD OR BAD, as to how it performs.
I have a solid roller 408 here that with a little nitrous help, will make PLENTY of power to get into the 8 second zone, and spin a good 8500 rpm, no problem. Or, I can put some dish pistons in it and boost it via a gear driven procharger/vortech, or I may just build another entire motor setup, regardless, it will be a solid roller 8500rpm deal. I'll make 1100 at the flywheel, one way or another.
Car works, always has. I have a VERY good tuner, that will be 100% right no doubt in that department.
If you think the tranny will hold up... send me one. I'll cover the shipping to and from you, when I have to send it back. Send me a tranny, and I'll put it in my car and we'll see just how well it holds up, in a race car.
I've put this out there in the past, and not once have I had someone willing to send me a 4l60. I've had offers for Th400's, Th350's and glides, and an offer to put a 4l80 in, but noone wanted anything to do with sending a 4l60.
It's time to put the product where all the talk is, and see if it will stand up to the hype.
3600 lb car 1.41 60ft on motor. Has several hundred passes in the 1.4 60ft range.
I think all the haters need to get a better trans builder.
I think keeping it cool is the key. I run the biggest trans cooler I could find with a trans pan that holds two extra quarts of fluid.
Trans has never skipped a beat.
Like I said. Someone thinks they can get one to live in a race car, time to put your work and parts to the test, send me one and I'll see what it can take.
From my exp.. as soon as I say 8500 rpm, everyone (tranny guys) run and hide.
1.45 60ft @ 3550lbs 10.5 @128 C + 125 shot, driven to the track 80 miles one way.
This is my second car with an FLT 4L60 and I have been very happy with their transmissions.
JL for your more race oriented car you really don't need a 60E and the reason why someone is not going to give you a trans as you have asked is there is no need to do so. They have their info that they work already from many of their current customers / vendors.
