Removing Gunk From Engine Bay
I'm trying to clean up the engine bay and paint it while I have the motor out.
I've had good luck not useing some super chemical. Some mild stuff like foaming engine cleaner, and just dawn warm water, and some brushes. scotch bright pad scuff, wipe is down with cleaner non residue paint prep, and paint comes out really nice for $20-30 in supplies.
If you not going black, to macth the car you can get the color in GM cans. Like $8-10 for a mini spray can. I dont think it has clear? so matches the stock bay with no clear from the factory. I redid mine agian with a can with clear, and looks good really shiny. From autotouchup paints.com or something? that looks really good too.
stock
http://i2.photobucket.com/albums/y11...n/IMG_0753.jpg
GM mini spraypaint
http://i2.photobucket.com/albums/y11...n/IMG_0983.jpg
online touckup paint
http://i2.photobucket.com/albums/y11...n/IMG_5118.jpg
http://i2.photobucket.com/albums/y11...n/IMG_5122.jpg
It is more for with the engine still in the car. However, you wont have to wipe the paint off a second time if you want to re-paint, which you would if you use a soapy mess and water.
Al
If you have some really thick grease, like it s 93 car with 150K and it just cloggs up a scrubbing brush, and you don't want to have to scrap it off its so thick. Oven cleaner works great, if you have a warm water hose to flush it off. Shake the can up good and spray it direct and let it foam up. it will turn brown in a few sec. And get a ton of thick crud off fast. Hose that off, and do it 2-4 times till it stops working, and go to warm water and dawn and scrub it.. Thats what I use on alum heads, intakes, rear ends and a few engine bays. I dont let it sit for the 30-45mins I think the can says just 30secs, maybe 2-3 mines and its never hurt any alum. Get the fume free or lemon sent. Its the best for cooked, and burnt crud. Its some strong stuff, try to use it outdoors and have a mask, glasses and gloves.
Getting the car warmer helps a ton too, if its out side or inside. Put a heater in or blow hot air into the engine bay. Even getting it over 50, normal winter inside garage temp. To 70-80 so its warm to the touch will clean it easier and better, huge help on engine parts
I just decided to go ahead and paint it black since there was no turning back.
-James
