Drag Racing Tech
Weighed a stock spindle today...
Old Mar 3, 2011 | 06:58 PM
onfire's Avatar
Coal Mining Director
Default Weighed a stock spindle today...
Read a lot of different weights....weighed one on our UPS scale just to see....
11.5lbs uncut.
Old Mar 3, 2011 | 10:42 PM
chrs1313's Avatar
thanks for the weight...trimmed I think dropped 1.5lbs for both sides
Old Mar 4, 2011 | 07:18 AM
SScam68's Avatar
I have mine apart as well. I'll try and get another measurement.
Old Mar 4, 2011 | 10:16 AM
00blacka4's Avatar
I write checks with my mouth that my ass can't cash
pics of said trimming ?
Old Mar 4, 2011 | 10:57 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
Trimming of the caliper mount ears is required for aftermarket brake kits on the 93-97 spindles and some kits on the the 98-02. They are different spindles due to the brake change.
Old Mar 4, 2011 | 04:24 PM
studderin's Avatar
http://www.racecraft.com/index.php?m...products_id=74
# Stock Spindle Weight: 17.2 Lbs (Each)
I guess thats wrong?
Old Mar 4, 2011 | 05:25 PM
SScam68's Avatar
No
Got some weights.
The cast portion weighed in at 10.5lbs
The actual spindle weighed 8.0 lbs
Total 18.5lbs
Old Mar 4, 2011 | 05:28 PM
studderin's Avatar
some info just call racecraft and burkhart.
that racecrafts 17.2 posted weight for a stock spindle, is WITH the wheel bearing.
There normal spindle is 10.8
the ultralights are 7.8
They will only make a 2inch drop, some say its too low? They can make them to with the stock (rack) tapered outer tierod (or they bunpsterr kit is tapperd too). They also clear 16 and 17 stock rims.
The burkharts are lighter I was told about 7-8#s
They make them with drop for stock. .5, 1, 1.5, and 2 drop. They are for a strait hole tierod, but they make a bumpsteer kit that fits the stock rack (metric) so you can keep PS. They fit 15 rims, but don't fit 16 rims, they hit the top of the spindle.
Old Mar 4, 2011 | 08:22 PM
InsaneAuto86's Avatar
If only there was a light-weight, !ABS, street version...
Old Mar 4, 2011 | 09:00 PM
00blacka4's Avatar
if there was a street version that saved 18ish lbs id be all over it...
Old Mar 5, 2011 | 05:57 PM
ssvert99's Avatar
your better off to run a stock spindle and invest in light weight brakes... there's much more of a performance gain than just a few pounds off the spindle.
The spindles are a great addition if you are spending the coin to go with an entire front end kit like ours that includes every part in the front of the car, and only weighs in at 90 pounds. That's for everything all the way down to the hardware we supply with the front end kit that has the k-member, control arms, tubular ultra light spindles, steering, shocks, and Strange brakes!
Old Mar 6, 2011 | 09:31 AM
JL ws-6's Avatar
Race your car!
I have the burkhart spindles.. I went with a 1.5 drop with mine. I did the 1.5 drop, because I had the front of my car 1.5 inches lower then stock, and had to decrease the downtravel by about 3 inches to keep the nose down, this way I have 1/2 of that built into the suspension now as well.
I also swapped to a 27 inch tire, to aid in preventing red lights... I was getting close to red lighting on a pro tree with 26's and 9.5 power, with the added power I will have (roughly double) the car's going to react a good bit faster, this will help prevent the red lights/decrease the learning curve some. I also, am going to set the front end with about a 1/4 inch of shift with 1 tire, so that way I can aid again, in preventing red lights.
Old Mar 6, 2011 | 10:16 AM
Steve Burger's Avatar
LS1TECH Sponsor
Adding spindles at the same time you do brakes is a great idea. The spindlws use a 3rd gen brake and not the 4th gen style. There is not a ton of price difference between the spindle and brake package VS the 4th gen brakes. You also need to take into account the weight of the 4th gen hub. It is very heavy and will be replaced with the spindle.
Old Mar 6, 2011 | 02:38 PM
onfire's Avatar
On the same scale, a Strange 4th gen Pro 2 racing brake plus the cut factory spindle weighed 28lbs.
A tubular spindle and 3rd gen brake will be 23 to 25 lbs depending on which tubular spindle you use...not a huge difference. If you are after every ounce for racing it is worth it since the cost is a wash.
Old Mar 6, 2011 | 03:00 PM
PRAY HRD's Avatar
Just weighed the spindle and Strange aluminum hubs i just got and came out to 37.2 lbs for the pair (18.6 each). Why does that seem heavy to me?
Old Mar 6, 2011 | 03:08 PM
onfire's Avatar
It's not. Throw the calipers, rotors and linings on there with it and it will come to 56lbs.
Old Mar 6, 2011 | 03:12 PM
PRAY HRD's Avatar
And whats the weight with stock calipers, pads and rotors?
Old Mar 6, 2011 | 03:15 PM
PRAY HRD's Avatar
I got 61.0 with the rotors, pads & calipers inside the boxes and packaging which is also what it weighed from fedex.
Old Mar 6, 2011 | 03:17 PM
onfire's Avatar
93lbs all stock. 56lbs stock plus Strange. 37lb reduction overall.
Old Mar 6, 2011 | 03:48 PM
PRAY HRD's Avatar
Not bad but was hoping for 45+. Thanks for the info! Got the whole setup for $560 shipped so i'm not complaining!!
