Can I run green slime in my slicks?
My slicks leak down all the time when its sitting on the trailor. I have heard you can use green slime. I don't run tubes. I think if I did I would have to put in screws because the tires move about a quarter inch on the wheel each run.
Any side effects to this?
I ran slime in my 28x10.5's last year. Driving around in the pits and got some kind of sharp metal object in the passenger side one. I didn't have a problem at all with it. You could also use permatex high tack on your tires if you don't want to use screws. If you use screws I'd put a dab of silicone on them so they're not as prone to leak any air.
For a drag-only car sure, but for the street, no way!
