Drag Racing Tech
99 Z28 275 Drag radial build
Old 09-04-2011, 11:21 AM
WheelsUp84z's Avatar
Default 99 Z28 275 Drag radial build
Well I guess I'll start a build thread since i'll be getting into this project in full force very soon.
Current mods:
Moser 12 bolt narrowed 2" per side 4.10's/spool/35 spline axles(going to 3.55's)
Spohn DBL Adj PHB
Spohn DBL Adj LCA's
Relocation Brackets
Strange 3" CM d/s
UMI Tq Arm- tunnel mount
Weld RT-S wheels, MT DR's and S/R fronts
Things to do :
Coan TH-400 w/ Brake
Coan 3800 converter
Spohn K-member
Spohn Upper and lower Control arms
Spohn Solid motor mounts
Relocate Battery
Install kirkey Seat
Install Hood
More Weight Reduction
Removed excess wiring from the harnesses
Some pics to start it off!
Old 09-04-2011, 01:21 PM
dhracer's Avatar
Very nice!!!
Old 09-04-2011, 03:43 PM
navyblueSS's Avatar
Nice!
Old 09-07-2011, 07:33 AM
1904gto's Avatar
Nice build keep us updated
Old 09-07-2011, 10:06 PM
Small update: alternator is shot, so it looks like i'll have to add yet another thing to the to-do list before it makes it to the track. Was gonna run it stock motor with a good suspension and drivetrain and see what she does before i add the cam and spray
Old 09-08-2011, 08:39 AM
blu byu EH's Avatar
owwwwwwwwww cool... Ill have to keep an eye on this one!!
Old 09-08-2011, 08:41 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Looks good, have you removed the rear coil "cups" and put done the heater hose mod?? Should get some of that gap out.
Old 09-08-2011, 10:30 AM
Yeah the rear has the heater hose mod done, It sits really high in the back because the car was on jackstands for like 8 months (and the frame was still on stands in some of the pictures), and then i just put some stock replacement shocks ($20 monroe cheapies) on the car till i can get it driven to the shop and start working on it. I'm going AFCO DA's and picking up some of the madman spring mounts to run a coilover spring in stock location, and will be able to adjust the ride height.
Old 09-14-2011, 11:01 PM
change of plans.... Boost is on the way!
Old 09-15-2011, 12:51 AM
z28241's Avatar
Uh ooh!!
Old 09-15-2011, 04:24 AM
LongIsland63SS409's Avatar
Going to be a nice build!
Mike
Old 09-15-2011, 06:32 AM
djfury05's Avatar
What happened to the QA1s? Thought you said they were pretty comparable to AFCO DA's???
Old 09-16-2011, 06:25 AM
I have QA1's for the front
Old 09-18-2011, 10:52 AM
outtacontrolz28's Avatar
Cant wait to see it finished man. The jackstand where actually under the rear the whole time. I dont know why it sets so high in the rear.
Old 09-18-2011, 08:54 PM
Oh really? i figured they were on the frame and the rear hung down. Hmm... Any rate, spent today working on the formula, as I have a big event next weekend (Holcomb Motorsports civil wars) And it seems as though the rear QA1 shock is messed up internally. Afco's on the way, damn these cars are getting expensive to upkeep 2.
Old 09-18-2011, 08:57 PM
Yesterday's work.., cut the inner fender metal off, pulled off pretty much everything accept the body harness out of the front end. Oh and got the motor/trans pulled out of the car! I think I unbolted/cut/removed a solid 40lbs of stuff off the front of the car yesterday (thats not going back in) Still have to chop up some brackets and the radiator support, which i'm guessing will give me another 10-15lbs of metal gone. Plus I have tubular kmember and a-arms to install too, gonna be a light car when all is said and done.
Old 09-19-2011, 08:48 PM
More cutting and cleaning up of the engine bay today.. Removed the cowl, still need to put in the patch panel for that. I also removed the fuse boxs/harnesses on the driver side, going to thin those things out and get rid of all the stuff I wont be needing, and tucking it up on the opposite (bottom side) of where it was originally mounted. Also picked up my Water pump for the A2W IC, got my BOV and WG in the mail too.
Cowl in stock form
Me working my magic
After:
Pile of junk removed so far! (AC and heat and all the ducting was gone when i got the car)
Old 09-19-2011, 10:06 PM
studderin's Avatar
still gotta cut the back of the fender metal
Old 09-20-2011, 12:45 AM
azimm1984's Avatar
you guys and your cut off wheels make me want to do bad things to my ws6 lol
Old 09-20-2011, 09:07 AM
Studderin- I wasn't sure of there would just be a hole behind that so I didn't cut that off yet, guess I'll be doing that this afternoon! I'm dreading going through the harness, web though in an avionics tech and do this stuff for a living, it gives me headaches just thinking about it. I'm half tempted to just buy a painless harness and wire in te bare essentials.
Quick Reply: 99 Z28 275 Drag radial build
