Drag Racing Tech
Another build thread
Old Oct 19, 2011 | 02:26 AM
  #61
WheelsUp84z's Avatar
I'm pretty much sold on that bumper support, looks like it fits really nice in there. I was going to do the fuse box thing like you did but decided to just remove it all and tuck it on the inside of the fenderwell instead of leaving the wires in the engine bay.
Excuse the dirtyness and rust (from all the grinding i've done in the engine bay)
cover for it
Old Oct 19, 2011 | 07:44 AM
  #62
subhumanzz's Avatar
Looks nice, I plan on making a cover for mine too. I'm not into the making everything look completed stage yet. I'm still I'm the getting it running right stage.
Old Oct 22, 2011 | 05:18 PM
  #63
subhumanzz's Avatar
hopefully the car will getting tuned this week, stay tuned.
Old Oct 29, 2011 | 05:28 PM
  #64
subhumanzz's Avatar
Results here: https://ls1tech.com/forums/drag-raci...l#post15564089
Old Nov 23, 2011 | 03:38 PM
  #65
subhumanzz's Avatar
Well, I'm still fighting an oil problem with the fitting in the valley cover. I put a -12 baffled fitting in there and it didn't seem to help much so i took it a step further. There is a turkey race this Sunday which will probably be my last race for the year so i plan on testing it out then. It's getting old pouring out a half a quart of $9/ quart oil every other pass.
Old Nov 24, 2011 | 12:02 AM
  #66
Mighty Whitey's Avatar
Wow I would have never thought there was that much oil splashing up through the "lifter valley" of one of these motors. You think it has anything to do with the placement of your fitting towards the rear of the block, where the factory oil drainback hole is? Maybe moving it in the middle would take care of it (if you had it to do all over again)?
Old Nov 24, 2011 | 08:37 AM
  #67
LS1SpeedAddict's Avatar
This wont work if your using a vacuum pump. It will help if your just venting to a can. The best spot is in the middle of the valley cover because its between the two cam windows. Reason I know is I have a much more sophisticated baffle system than this and it still sucks some oil. Good luck, and STOP BUYING $9 oil!!
Old Nov 24, 2011 | 09:21 AM
  #68
subhumanzz's Avatar
unfortunately i dont have a vacuum pump on here yet. the plan is to get one over the winter. how do you recommend me to vent it with the addition of the vacuum pump? i think that under high rpms the oil just flying off the cam and splashing directly onto the fitting and thats why its sucking so much into the can. im all ears if someone has a better way to do it.
Old Nov 24, 2011 | 10:06 AM
  #69
If you plan on racing 1/8th mile then you might be fine. The majority of the oil is sucked the other end of the track. I was thinking of pulling from both valve covers if my problem got worse. Pulling from both cuts the CFM in half so it should pull less oil.
Old Nov 24, 2011 | 10:36 AM
  #70
subhumanzz's Avatar
i dont think i can fit a fitting into my valve covers with the rocker setup, thats why it went into the valley. im thinking when the pump goes on i will try to put the fitting at the front of the valley cover. out of curiousity why would my current set up not work with a vacuum pump? i know nothing about them except for the fact that i need one.
Old Nov 24, 2011 | 11:16 AM
  #71
The vacuum pump will suck the oil right threw that box you made. I have 5 baffles in the box I made and it extends to the middle of the block where its sealed and it can only pull from 4 small holes at the top and I still get oil.
Old Nov 25, 2011 | 02:53 PM
  #72
subhumanzz's Avatar
if you have any pics of your valley cover/ vacuum pump set up i would love to see it as i am going to be changing this around shortly and would like to do it right the first time, i appreciate it.
Old Nov 25, 2011 | 03:38 PM
  #73
I haven't quite figured out how to do it right either lol. Mine doesn't pull a whole lot of oil anymore but it still does. 1/8th mile racing wont be a problem. I don't have any pics before we welded it up.
Old Feb 5, 2012 | 04:55 PM
  #74
subhumanzz's Avatar
got the hood back from paint today:
Old Feb 5, 2012 | 06:04 PM
  #75
studderin's Avatar
that looks really good. no more black hood
you know the race weight?
Old Feb 5, 2012 | 07:35 PM
  #76
subhumanzz's Avatar
not sure what its going to come in at this year. still have the brakes and spindles to go along with a few other weight saving ideas. hopefully around 3200 with my 240 in it.
Old Feb 5, 2012 | 08:42 PM
  #77
SSPerformance's Avatar
hood looks good painted
Old Feb 5, 2012 | 08:51 PM
  #78
BOBS99SS's Avatar
Captain Double Post
car looks great, i went so long with out getting my hood painted it was like a new car when i got it done lol
Old Feb 6, 2012 | 10:05 AM
  #79
ATwelveSec02Z28's Avatar
Im gonna try pulling vacuum from the valve cover.... Of you have any luck on anything let me know.
Im getting almost 1/2 a qt on 1 full pass.... and its blowing oil mist everywhere.
Old Feb 6, 2012 | 02:24 PM
  #80
subhumanzz's Avatar
i ended up getting a new valley cover and ditching the -12 line i had in there. i was having alot of oil misting too so i ended up just wrapping a rag around the filter which seemed to help. i have since went to a vacuum pump but havent yet been out in the car to see the improvement.
