Drag Racing Tech
MY 01 Z28 T-56 record chaser build.
Old 04-16-2012, 05:08 PM
  #141
djfury05's Avatar
Originally Posted by thels1lover
air to air or air to water?
a2a..
Old 04-28-2012, 12:45 AM
  #142
Darin D's Avatar
To answer a few of the questions that have been asked.. The engine sees full boost at around 4700 rpm. I will take some pics of the dyno graphs next time i am there, the rpm pickup doesn't work on that dyno so they are just based on speed. Yes I have a pump/sprayer setup on my t56, it turns on at 4k rpm. The camshaft is a comp lsr 227 / 223 .614/.610 115 LSA.
The car is a lot of fun on the street i've been driving it around a lot and I love it. Put a couple bus lengths on a mid 90s mustang that floored it next to me the other day, i just rolled into 3rd and shot past him like he was on the brakes. Only thing I don't like about the car is the spool, makes it kind of a pain in parking lots and doing u turns. It's not that bad, but i do wish there was an lsd available that would hold up.
Old 04-28-2012, 12:52 AM
  #143
TheLS1Lover's Avatar
How about the True Trac Option for the S60? How does Jessica like it? (assuming she had rode/drove in it)
Old 04-28-2012, 01:24 AM
  #144
Darin D's Avatar
Strange told me the tru trac wouldn't hold up to 1000+ with a 6 speed. they said spool was my only option.
Jess has not ridden in the car since i turboed it she will though. We are planning on lining up on the highway soon, my car vs her supra. I gotta get a set of drag radials first though, these old slicks aren't worth a **** on the highway.
Old 04-28-2012, 07:48 AM
  #145
studderin's Avatar
How did you hook up the trans pump to active at 4K? Sounds Like I good way of doing it, I was thinking just a WOT switch
Old 04-28-2012, 08:18 AM
  #146
Race your car!
JL ws-6's Avatar
Tru crap would NEVER take that abuse, they break with 350 re in a 3600 lb car. Now that the car makes dome power what is thd plan for the safety side of things, and how do you plan on building boost on the line with it?
Old 04-28-2012, 08:40 AM
  #147
studderin's Avatar
ya, I didnt see the question about going to a truecrap, you can try it. But alot of people have with less power and going slower, had them fail, and like the spool better. I almost crashed my car a few times, with a true crap. keep them for rock crawlers or some ****. M6 hit only the passenger side driving, is not fun. Spool all the way.
https://ls1tech.com/forums/drag-raci...-truecrap.html
https://ls1tech.com/forums/drag-raci...p-6-speed.html
Old 04-28-2012, 10:02 AM
  #148
jetaws6's Avatar
What about a wavetrac? Isnt that supposed to be pretty stout?
Old 04-28-2012, 07:19 PM
  #149
Race your car!
JL ws-6's Avatar
Wavetrac = junk just as well.
Old 04-28-2012, 07:31 PM
  #150
Zmg00camaross's Avatar
You will get use to the spool. Its not that bad.
Old 04-29-2012, 03:55 AM
  #151
nmass399's Avatar
Sounds good man, i have gotten use to the spool. Rides alot better with bias ply's with the spool when goin slow.
Old 04-29-2012, 09:38 AM
  #152
djfury05's Avatar
How is a differential with a lifetime warranty junk?
Old 04-29-2012, 02:27 PM
  #153
TurboStangJON's Avatar
Limited lifetime warranty, which to me is a way of saying no warranty . I'm sure it will be considered limited when they hear what it's behind. It's junk for this application.
Old 04-30-2012, 10:47 AM
  #154
blue99fbody's Avatar
buddy has a wave trac in his 9.9x m6 t/a and its been locked up like a spool for 6 months and wont unlock.
Old 04-30-2012, 01:14 PM
  #155
Darin D's Avatar
Yep thats basically what i've heard from everyone, that the tru trac and wave trac will not hold up at all for me.
I've been out of the country for a week, get back tomorrow and the first thing im doing is getting the interior pulled apart and bringing it to the chassis shop. As soon as the cage, chute, ds loop, etc are done it is going straight to the track. I can't wait to see how it does, it will be a challenge with the amount of torque this car makes but luckily with the Motec ecu i can setup gear/rpm based timing tables to control power as well as very precise boost control should help.
Old 04-30-2012, 06:28 PM
  #156
WheelsUp84z's Avatar
my tru trac did pretty good in my car for th 10k miles and probably 100 passes i made on it. 402/nitrous 6 speed setup in a 3700lb car on a bias ply. car made 665/760 on nitrous.
Old 04-30-2012, 06:37 PM
  #157
Man I wish I could fast forward. Out of the gate what are you hoping for? With your driving I have no doubt you will get the record!
Will this one end up going methanol like the Supra?
Old 05-01-2012, 12:07 PM
  #158
AChotrod's Avatar
Ill be pulling out my Tru track for a spool soon. So if you wanna try one for cheap let me know. Im not making the power you are but I made 415rwhp on motor with a t56 and hit it with a 200 and it was fine.
Old 05-15-2012, 08:57 PM
  #159
djfury05's Avatar
Update?
Old 05-17-2012, 09:11 PM
  #160
Darin D's Avatar
still saving up to get the cage done..i could go to the track and do some 1/8th mile hits i guess but i'd rather get the cage and chassis work done first to avoid twisting the car up.
Quick Reply: MY 01 Z28 T-56 record chaser build.
