Nitrous gearing, what neeeds to happen here?
copied from yellowbullet
Combo is a 355" LT1, Ported 21 degree trickflow heads, stock ported intake, 13.4:1 Compression, E85, T56 6 Speed Manual Trans 4.30 rear gear
232 238 .629 112 LSA Hydraulic Cam
28x10.50 Hoosier Stiffwall
4.30 rear gear
Took it out for some shakedown passes yesterday, and it will hit the tires super hard, pull the wheels, then set down and bog.
It was cutting 1.89 60' times like this N/A.
I started spraying it on a 150 shot (.062 jet through an EFI Plate) and it started to 60 better, but I would run out of gear before the 1000' mark...
It went 1.56 1.53 on the .062 jet, then 1.49 on the .071 jet
The cam loves to pull at 6700+ but I dont know how far I can take it with the valve train thats in there...
Should I regear for the nitrous, swap to solid valve train and spin it up? What gear should I go with if I regear? I eventually want this car to run 9.90's
Should I get suspension before I do any gear swaps or spin it any higher? I plan on full AFCO Suspension from MADMAN.
Heres a video of an N/A launch at 6200 on the 2 step.
http://www.youtube.com/watch?v=jcQc4rK1xiI
Here's a video of an N/A launch at 4800 on the 2 step.
http://www.youtube.com/watch?v=2uKnZlFVG50
It is virtually the same 60ft time for both runs. Upping the 2 step and hitting the tires harder had no effect on 60, just a lot more violent in the first 10ft...
Here is a launch on the 150 jets, 1.53 60ft
http://www.youtube.com/watch?v=hDFYjNO-_Tw
Any help is appreciated.
4.30 rear gear
I'm seeing the traction, maybe try launching higher or increase the tire pressure to allow a bit more tire rotation to keep RPMs up. Are you running a stock weight or lightweight flywheel?
Spray more nitrous off the line and put a 3.90 gear in it. You could use the morel link bar type lifters if you didn't want to go solid, but solid would make more power, spin higher, and be more reliable at those rpm's. I'd say with your CR you could take advantage of a bigger solid roller camshaft spec'd out for a heavier dose of nitrous.
What tire pressure were you running? On the nitrous pass it looked like it wadded the tire up pretty good. You got separation in the rear suspension now which is good, and the front end looked like it popped up well transferring weight nicely. Like the guy above me said about the tire pressure try adding some more air to get more wheel speed.
