who flashes and stalles off the line
Just wondering if people have noticeable results. Doin one over the other. Also what size stall and how high are you'll launching at
when i had my P.I. 3400, id usually stall it to 2500 and then floor it. 1.49 60' on 12-11-11
with my circle D 5C converter, i usually stall it to 3400-3500rpm and then floor it from there. seems to be the best technique for me.got a 1.46 60' from it on 6-15-12
If the car 60's better by "smacking" the converter off idle, then it's too tight to begin with, seeing as a converter will flash higher than it will foot brake too.
With my 10" edge 3400, I pulled numerous 1.54 60's with a 15-1700rpm launch, pulled a 1.52 by stalling to 1800, and I can foot brake it to 28-2900 easily. Waiting for cool weather and possibly try some 2-2200rpm launches to see if it helps the 60' any more
Mine is about the same in the lower rpm range. But if I load up too high it will start to lift the *** of the car which makes it hard to squat once you release the brake....and less chance to hook like mentioned above.
I just did my pinion angle and my lca angle. It must been way off.cuz something would always hit the undercarriage around the back seat when I go through bumpy roads.now with everything. Set no more hitting or bumping on undercarriage I saw where yoke n torque arm wer hiting the floor.hopefully this will help wit my 60ft
Flashing slows down 60ft by around .05-7...but could help hook on marginal track
If you got teeth on your track stall her as high as the brakes will hold...
1.281 60ft here with h/c na motor at 3k race weight...
Still would like to try and running dual rear calipers to see if I can squeeze a few more .01s
...maybe if I get bored
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
