E85 Guys come on In..
Whats the pros n cons of E85 and is it hard on anything?
I wanna be able to run either 93 or E85 if i do this thx.
Now I am as high as 126% duty cycle at 7500rpms to keep the AFR mid 12's on a gas scale.
Shake down passes with the single pump at the track ran 7.10@96mph on motor going down the track at 14-1 AFR and the timing jerked down because I didn't figure the single 255 with hotwire would be enough.
It has taken some messing with but I"m glad I did it.
For the above setup I would start with one of the new e85 rated walbro 420 in tanks which is what I'm about to order, keep those same injectors and just see where they take you too although I think you'll need 80lber's. FIC can reflow them up to 80lb I believe.
Also run a -8 feed and use the stock feed line as a return with an external reg after the rails unless you luck out and somehow the stock bypass regulator in tank can support the return flow of the 420 but I kinda doubt it.
I used the stock basket cut up a bit and a 3/8 to -8 adapter fitting to run -8 to the top of the stock bucket. My factory sending unit still works correctly and I bypassed the factory fuel pump wires.
Like I said I personally am ditching the dual pumps and going to a single 420.
Mine with a sbe ls1 head cam intake setup with 60 lbs injectors and 340 aeromotive intake and Hotwire. Also loop your rails I you have fast rails. I am going to twin 340's
OP- Start with a non-extended tip plug in a 6 or 7 heat range. Timing might end up lower than on gas. Lots of fuel pump needed, I ran out above 425whp with a single 255. You'll gain some good torque in the midrange, might make more, the same, or less at peak. Average #s will go up 2-3% I'd reckon. I've been running E85 for 3 years now in my LT1, over 13:1 compression on the street
fuel pressure is 65psi with vac line off the regulator. These injectors were reflowed at FIC to 55lb@58psi. I can tell you whats wrong, I suck at tuning and put in the number wrong to convert my wideband through the EGR so it read incorrectly and I wasn't looking down at the actual gauge. Actual AFR was 9.5-1 when the gauge on hptuners would show mid 14's on a GAS scale.
I'm still working with it. I'm only sharing my lack of experience so maybe it will save someone else the same mistakes. If e85 wasn't so forgiving this engine would be grenaded.
New setup in my sig will have dual walbros and 90# at 58psi injectors. looking to make between 550-600whp, dynamic compression is 10.5:1
If you can do a fuel system without spending ton's of money then the e85 is kind of worth it. Lets face it 3-4 bucks a gallon for e85 vs 10-15 bucks a gallon for race gas adds up quick.
I did not worry about going to the trouble of changing my wideband settings and hp tuners to read e85 vs 93. Either leave as is and tune on the wideband like regular gas or use lambda. Just makes it that much less of a headache to worry with. Just make sure you change the stoich in hp tuners.
The pros i know of are:
Cooler IAT
Higher Octane
Cheaper per gallon than 93
Smells good
Usually makes more torque.
The fuel is oxygenated.
Cons:
Gas mileage will go down a hair depending how well your tuner does part throttle tuning.
Not that available in certain places
$ spent on getting bigger injectors and pump or pumps.
In a performance aspect it will only be superior over 93.
Cooler IAT
Higher Octane
Smells good
Cons:
Cooler IAT
Higher Octane
Smells good
Cons:
poke around the internet on some furums with a lot of e85 activity to learn more truth from people using it , most half truths come from people that have never even tried it. turbo buick furum (t type & grand nationals) has an e 85 section and many people running stock tanks, lines ,etc.. just bigger injectors and pumps on milder builds then stock supply used as return with bigger supply on stouter builds.
pretty much any boosted platform you will see the fastest cars running e85 or e98 whether its SC'ed mustangs , supras , evo's ,etc..... theres also a lot of info on the e85 forum allthough thats kinda ramping down now that so many platforms have their own e85/alternate fuels subforums where info most pertinent to the vehicle you are converting can be found.
its mostly going to be a street car that will see a few drag strip passes everynow and then to try to get better #s Would you suggest E85 a good fuel for a weekend car?
