Drag Racing Tech
shock settings for rear
Old Jun 1, 2014 | 06:53 PM
loosews6's Avatar
Default shock settings for rear
i have double adjustable Viking shock on a 99 trans am f body 28x10.5 stiff side wall with tubes my rear shock are set on rebound is on 14 clicks off full loose they have 18 clicks.
compound is on 2 of full loose. car is squatting bad and balling up click still been 1.27 1.31 60ft but I think its hitting tires to hard.....
here 1.27 60ft
Old Jun 2, 2014 | 08:08 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
Not very good video for diagnosis purposes, but for the issues you mention I would start working with front end shock valving and limiters and you can also take some LCA angle out of the rear.
Old Jun 2, 2014 | 07:13 PM
old93camaro's Avatar
if im reading this right you have rebound on 2 and compression on 2 ? Or you mean rebound 2 and compression 16
Old Jun 3, 2014 | 07:57 PM
loosews6's Avatar
rebound on 14 compression is on 2.....
Old Jun 4, 2014 | 08:45 AM
ssvert99's Avatar
I know where you're going... Keep in mind he's on a slick and will require complete different valving setup than a radial tire car.
Old Jun 4, 2014 | 06:10 PM
lol yea i was about to try that out lol
Old Jun 6, 2014 | 04:02 AM
TTur1996's Avatar
Imo the back looked fine. Looked like it hooked good. I didn't see the back squat at all. The problem looked like your front is coming up way to violent. If you have adjustable shocks in the front, try adding a few clicks to slow down your rise. If that doesn't work you may have too stiff of springs in the front. Coming up that fast and hard you may be unloading your rear a bit. I could not see if your tires spun a little. If they are spinning a little after you get the front slowed down, you may have to back off the back a few clicks.
Old May 22, 2019 | 05:21 PM
Chase99TA's Avatar
here 1.27 60ft J@woodstock - YouTube
What ended being the final adjustments and outcome. Thinking of starting with 4c and 15r
