Post your BEST 60's and your wheel/tire combo
I am trying to see if 26x9 inch Hoosiers on Centerline 15x7-7.5 rims can hit a 1.48 sixty.
What are your best sixty foots and what were your suspension mods and wheel/slick combo?
Thanks guys,
Chris
It's no good to have the power if you can't hook it.
Thanks guys,
Chris
D(irecto)r Pepper
Welds 8"x15"
E.T. drags 26"x10" at 14 psi
Suspension.
GM 1LE rear sway bar (stock bushings)
GM stock torque arm (poly bushing)
Lakewood LCA/PH with poly busings
GM 3.73 gears
Right rear air bag at 15 psi
GM stock V8 rear springs/shocks
Thats about it.
Suspension.
GM 3.73 gears
Thats about it.
Wheels up Director
My best 60 was a 1.52. That was with the completely stock suspension down to the rubber bushings. I was using 15x8 Draglites with 26x10.5-15 ET Streets set @ 18PSI. That was before my major weight reduction and internal mods <img src="gr_stretch.gif" border="0"> I can't wait to see want it will do once I get back to the track <img src="gr_grin.gif" border="0">
LAter <img src="gr_grin.gif" border="0">
1.60 w/ 26x10.5x16 ET streets mounted on SLP 16x8 takeoffs. Suspension included !front swaybar, PA k-member& a-arms, BMR SFC's, Hotchkis LCA's, Hotchkis APHR, and Hotchkis rear swaybar.
1.53 w/ 26x9x15 Hoosier slicks on 15x8 Pro Stars. Suspension: same as above plus BMR full length torque arm and fronts Hals w/ drag springs.
later,
Steve
later,
Steve
Thanks for the info guys, I am hoping with 26x9 inch hoosiers and Centerlines I will be in the high 1.4 to low 1.5 range.
Cheers,
Chris
Cheers,
Chris
15x8
26x10.5x15 M/T E.T. Streer tires 15 psi
1.59 with the completely stock suspension and M6
Good luck Chris <img src="gr_stretch.gif" border="0">
1.494 60'
Bogart D-10's 15x3.5 w/ET Fronts 26x4.5
Bogart D-10's 15x9 w/6.5" BS
ET Drags 28x10.50 w/MT Tubes @ 15 psi
Suspension:
Random Tech Adj. Torque arm
BMR Chromoly Adj. LCA's
GWS LCA Relocation Brackets
V6 rear springs
RR Air Bag @ 20 psi
Wolfe Chromoly SFC's
HAL Shocks (F/R)
HAL springs (front)
PA Chromoly K-member & Lower A-arms
GWS PHR
Strange 12-bolt w/spool & 4.56's
Gordon
Suspension:
V6 rear springs
RR Air Bag @ 20 psi
HAL Shocks (F/R)
HAL springs (front)
GWS PHR
Gordon
