Belt routing with "Race" electric water pump
Hey, how are you guys running your belts with "race" versions of EWP that don't have the middle pulley?
I feel dumb asking, but I cant find anything when I search. Plenty comes up for the street versions, but not the race versions.
Thank you!!
Thank you!!
All these diagrams go crank then over tensioner. Go crank, alt, ps, under tensioner, back to crank. Second one is close. Stock alt bracket will work just needs countersunk on one bolt and a correct size flat head bolt. No aftermarket brackets necessary just put it all on and roll belt on the crank like you’re turning the engine over
The following users liked this post:
Magnet (06-29-2020)
Magnet (06-29-2020)
Or get one for the street....the pully spins on a bearing...like an idler
https://www.ebay.com/i/254385308066?...b3422dc9fde92f
sxc Z28 (06-29-2020)
No he won't. It costs a belt if you right size the belt and run it like the diagram i quoted. If you do away with that last idler it would still only cost a belt but the jegs adjustable alt bracket makes it much nicer to remove or install the belt.
i ran it like that pre adjustable alt brackets
