m/t 295/65/15 dr's some q's
LS1Tech Sponsor
yep, but they still won't fit. They're .2" shorter than the 315/60's.
http://www.mickeythompsontires.com/strip.html
then click on "ET Street Radial"
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
LS1Tech Co-Founder
Radial tire racing is interesting indeed. I wonder how much I can kick my tires back, enuff to fit a 29.5???? I can adjust the lca's and push the tires back an inch or more.
Don't you TA guys have a little more wheel well than the Camaros? Maybe someone that has a mounted set could take a string measurement and give you the specs.
It's amazing to watch some of the big HP cars make these tires work. I get to see them run a the World Street Nationals and last year the bump for the 32 car field was 8.66 @ 156!!!! All but two of the qualifying cars ran the new MT's.
Well I just bought that exact tire. I rolled it up to the car an it looks waaay to tall! So I had the guys send them back and order me some 325/50/15's instead. Maybe with all of your suspension mods you could get them to fit but I have a stock suspension and there was no way!
Rick
Originally Posted by 2001-WS6
I've got the 325/50/15's sitting in the basement right now. The height looks reasonable but these are some beefy wide meat patties. They will eventually go on a set of 15x10 Prostars with the 9" narrowed 1.5" each side but we are a ways away from fitting at this point.
Rick
Rick
Originally Posted by ramairstyle00
6 inches of backspacing?
It's actually narrowed 3" to a side. So I'm running 4.5" Back Spacing on the rims.
Rick
My brain wasn't functioning when I typed the last note.
Rick
Rick
ah. i'm narrowed 1.5 inches on each side and don't know how large a tire i can go with 5 inches of backspacing (centerlines limits)
I just hope my 325's dont stick out past the fender to bad. I really dont want to have to narrow the rear end any. In case I do though hoe much does it cost to get a rear end narrowed?
LS1Tech Sponsor
A local guy narrowed the housing for $150, the rest was done by Moser.
__________________
2016 Z07 Carbon
2016 Z07 Carbon
