just put on BMR extreme swaybar
wow this thing is awesome! it stays flat and level on the launch now i just need to get my QA1s on
it is quiet on the street and simple to adjust VERY worth while investment
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Glad to hear your happy with the bar
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
hey what are the proper settings for it? mine was put on in a shop but i seem to be haveing problems with my suspension so ima go through it and make sure everything is in the right setting..
7 Second Club
but yes it works very well along with the BMR Xtreme torque arm and their round LCA's and panhard bar.
7 Second Club
Originally Posted by Got Me SOM
does this weld on solid or does it have bushings? i need a rear bar bad now.
no u bolts.... that welds on... htne you have to rod ends that bolt to the bar and then weld to the chassis
imo, its a waste untill you are low low 1.5 60' or into the high 1.4 60' before it makes a difference.
"All Motor 9 Second club member"
Originally Posted by gator's 99TA
teh BMR weldes to the frame rails but also connects to the rear with poly bushings. its the most streetable among drag bars. the spohn is the same bar. the wolfe/billingsley is not for street use at all.
Is the BMR Extreme Anti-roll bar now available with poly bushings? I thought they were only available with rod ends and there's nothing quiet about them.
If so- Pics please
