got my 28in tires to fit
i fanily got my 28x12.5x16 Et Streets on car. there close. and with that big tire you can tell that the rear is not centerd, so i got some adj lower control arms comming. to sqaure it up and make a little more room.
here is the a pic of them
all so whats a good air pressure i should start out with?
http://i8.photobucket.com/albums/a22...s/DSC00797.jpg
http://i8.photobucket.com/albums/a22...s/DSC00801.jpg
no your right, it is a stock wheel for now, all i got, but if you seen it in person it hardly budlges out. you can hardly tell the diffrence from them anf my old 26x11.5 tires, just alot taller
Originally Posted by SiL3NtXWS6
you fit a 12.5tire on a 8inch wide wheel? Or do i have the wheel width wrong
it all good man, they are some big *** tires on stock wheels, whent out sunday to track weather wasnt best but i think the 28's are going to do the trick for me. got a few things to dail in, and still a few small places they rubbing when i turn, but thats about it
well man i run 17x11's ZR1's on rear, with them i had the inside fender bet in all ready. the 28's too ka little more there, i all so rolled the fender lip on both sides. and ru na 5/16th spacer for the wheels
only time they rub is when i turn tight, be cause of them gripping and the spool i have in the rear end. going down the track stright they dont rub, iv all ran it at track last sunday.
Originally Posted by tektrans
I think they are gonna rub. Please be carefull when you make your first run.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
