325/50/15 drag radials vs 28 x 10.5" ET drags
I've got a setup question on tire size and backspacing. I need to be able to run 325/50 15 Drag radials and 28 x 10.5" ET drags. Do you need any additional backspacing to have the same outside clearance? Between the two tire setups.
Phil
Phil
Choose your back spacing to fit the 325/50 the best you can. The 10.5 x 28" slick is a narrower section width and will just slip in place easier than the 325/50 and not worry about any clearance issues. This is also a good idea as the slick being a bias ply will have more sideways sidewall flex in turns and the added clearance over the 325/50 will go a long way to keep the sidewalls from rubbing.
If using two sets of rims, get the same back space for both.
I'm using Bogart bolted RT's.... 15x9.5"/ 7.5" BS. I've cut the spacer off the wheels and run 28-12.50-15 ET Streets(same as 10.50 Drag) without the spacer. Wheels/tires tuck in real nice. No inboard rubbing issues but is close
My M/T 325-50 DR's need the spacer to get enough inboard clearence.
I don't see how you could get the same outside clearence unless you ran two different back spaced wheels foe each tire-
No, I have to worry about the outside clearance. Right now my 28 x 10.5s are just tucked under the fenders. From the sounds of it, when I go to the 325/50s I am going to need to run a wheel with about an inch more of backspacing to get the outside to fit correctly.
Phil
Phil
