View Poll Results: Who has done the !bumper mod?
Voters: 413. You may not vote on this poll
How many have done the front bumper delete?
#101
So how many of you with T/A's are running without custom brackets? The nose is just so big...debating on making brackets or not before I put it back together.
#108
no...the foglights are actually connected to the support. Sooo unless you made some brackets, you give them up.
The secret....Just cut up the stock one
#109
Does the cover have to come off to remove the front support in an LS1 Camaro? I can see all the bolts the way it sits. Would be nice to be ablt to pull it wouthout pulling everything around it.
#110
Seams the Firebird supports are heavier than Camaros. If I can pull mine without removing the cover, I will try and see how much it weighs. I have seen 19-20lbs for a LS1 Camaro but also saw 12. Quite a jump.
#116
