bias ply slick vs radial slick
Originally Posted by MADMAN
I am getting alot more passes out of the Hoosier radials than we ever did with the bias ply. The key is running alot of air pressure and a short burnout.
wow. on a 9" wide tire, thats not leaving much contact, or is it?
i was leaning towards the hoosiers, as they are 2 tenths of an inch taller than the M/T, and i need everybit of it to make 1/4 mile with my gear/tire combo.
what type of power level are you running these pressures with?
im bumping on the door of 1.4x short times once i zip tie the heads on.
big thanks!
Originally Posted by cainsw
Hmmm, very interested in this. I've never tried to run more than 17psi in my ET Streets.
madman is referring to a radial slick.
depending on power, i wouldnt run more than 18 ever in an et street.
i had excellent results running mine at 15-16. 3460 raceweight.
