Rim Screw guys.....
Pretty simple process. What i did was had my slicks dismounted, did my holes, then put the tires back on in the garage myself(a little damn and some effort, and they will slide over the lip of the rim with the soft sidewall). I installed my screws, and THEN took them and balanced them(or else the screws might throw off the balance a little).
Good luck with it man!
that's alot of screws! Any particular reason you run that many, is it just to get the tire to evenly wrinkle, issues with breaking less screws?
I'm hoping not to have the movment issues with a radial tire... but on the other hand I bought the screws to put 16 per wheel (8 per side) if they move like the last set of bias ply tires I ran.... I see any more then a 1/4 inch of movement per run and they're getting screwed for sure.
I'm hoping not to have the movment issues with a radial tire..[/QUOTE]
With the radial tire you should be ok with 8 per side. Also with the radial tire you run more air pressure which helps the rim/screws hold the tire better. I never had any movement on mine with the radial tire and 8 per side.
What about the air leakage issues... what is everyone doing to get the tires to hold air after the drilling/screws.. I know tubes, but I don't want to go that route, not with a radial tire.
Madman-
Care to elaborate on the staggering you speak of?
I agree, mine actually hold air BETTER with the screws. Only reason i could think of for this is it holds the tire to the rim better???
My opinion 8-12 per side, per HP, more = more. I have done with tire mounted & not mounted. You should be able to feel without drilling thru tire. Screws do not go thru bead, or they would pop the tube. We always balance after screwing, as said, obvious reason. Never heard the stagger thing either, but if the man says, then it's probably correct. I always kept exactly the same, thinking it would help balance.
My slicks need a few passes to rotate a little but then don't seem to move again. I'm in the same boat of not wanting to drill holes.
Derek
Marked it with a template, center punched my marks, and drilled it slowly so it didn't catch and go through the tire when it broke through the rim.
I also kept them in-line inside/outside. The "staggered" way is interesting and I'm curious to the benefits.
