Drag Racing Tech
View Poll Results: which drag tire and tire pressure
MT DRAG RADIAL
50
51.02%
ET DRAG
15
15.31%
ET STREET
21
21.43%
BFG DRAG RADIAL
12
12.24%
Voters: 98. You may not vote on this poll
Which drag tire are you running
Old 06-02-2007, 07:35 PM
dnkynrbk's Avatar
Default Which drag tire are you running
which drag tire are you running. Which tire is the best with a suspension set up
Old 06-02-2007, 08:20 PM
slowmofo's Avatar
MT DR
seen cars go 8's on them, figured thats good enough for me..
plus I can drive to the track on them
Old 06-02-2007, 08:27 PM
James Montigny's Avatar
MT Drag Radials on Prostars.
Old 06-02-2007, 08:29 PM
SSPerformance's Avatar
* other Hoosier
Old 06-02-2007, 08:40 PM
brandonppr's Avatar
ET Street 26x11.5x17 on stock SS wheels
1.47 60ft best.
Old 06-02-2007, 09:16 PM
SSwanner's Avatar
MT et drags... i drive them on the street too, a lot!
did a 1.46 60' on them with a not so hard launch, with the stick shift.
Old 06-02-2007, 10:25 PM
Omega Doom's Avatar
BFG extreme 2 DR's here!
Old 06-02-2007, 11:18 PM
5_02ls1's Avatar
e/t streets {non radial] @ 18 psi...same tire all my buddies run as well
Old 06-03-2007, 08:08 AM
speedo's Avatar
Best I have done so far with a SA shock in the back is 1.54 on a 26x15 ET street. That was with the tire on the passenger side spinning all the way around on the rim. No rim screws of course. 17.5 psi.
Think I may try a 295 MT drag radial if they ever hit the market before I drill holes in them Bogarts. Hopfully I can get into the 1.4s when I put the shocks on up front.
I hear Hoosier has a good tire as well.
Old 06-03-2007, 08:20 AM
gator's 99TA's Avatar
i have run the m/t et drags, et streets, and et radials. i love the ET radials (325) the best b/c you can run them at 20 psi at the track and street, they are stable, comfortable, can drive in teh rain and go 1.3 60' times.
Old 06-03-2007, 11:25 AM
Violatorno1's Avatar
Other here too.....Hoosier QTP 27 x 11.5 x 15 on 8 1/2 x 15 Bogart SS
Old 06-03-2007, 10:18 PM
Retired Street Racer
Matt D's Avatar
MT Drag Radials here. 1.4X 60 fts.
Old 06-04-2007, 03:02 AM
razorclaw99's Avatar
et streets
Old 06-04-2007, 05:26 AM
omcar's Avatar
M/T drag radials here.
Old 06-04-2007, 04:08 PM
LSGunZ28's Avatar
am I doing something wrong if I have M/t Et street radials on 18 psi, dumping @ 5500 RPMs and it still bogs? is it due to the aluminum flywheel?
Old 06-04-2007, 04:46 PM
fasttagurl's Avatar
I second his answer except a 26X11.5X15 with a 1.44 60 foot!!
Old 06-04-2007, 08:59 PM
98SS1LWEE's Avatar
Had nitto's, but now... nothing hooks like a mickey ! ! !
Old 06-04-2007, 09:46 PM
camarokid94's Avatar
Mt et DRs love them stable 15PSI 275-40-17s 1.71 60 but that was long time ago will hit the track ASAP with the 402.
also have mt et streets in a 27 10.5maybe i think been a while 16 got them for the nitrous have used them but they bite way to hard for my old NO TQ H/C setup bogged bad.
Old 06-05-2007, 06:57 PM
CamTom12's Avatar
275/60/15 MTDRs at 22psi
Old 06-06-2007, 10:39 AM
6 & 8 Second Club
mrdragster1970's Avatar
Fast car Hoosier 34.5 X 17 X 16
Slow car Hoosier 29 X 10.5W X 15
