SFI 25.2 Mustang/LSx build "The Renegade"
#2563
Thats a heat wave...it was 4 degrees here today, i managed 3 hoours of work on mine, but i did have a tiny "little buddy" heater...didnt do too much in a 2 car garage though
#2566
OWN3D BY MY PROF!
I was looking at VFN's fiberglass doors earlier. I was thinking you could rig up a window regulator, locking mechanism in there and, cover them with sheet metal door panels. I don't think the weight loss would be as much apples to apples. They are priced decently at $624 / pair. Are mustang doors metal or SMC like Fbodies?
#2568
or invest in one of the little propane heaters we have one and the thing heats the two car garage quick. i spent the day in the garage yesterday we attached a tent garage to the two car and used the stove and propane heater kept us warm all day.
#2569
phil's shop is awfully big to heat...
those little propane heaters are awesome...mine will run me out of my 2-car in a hurry if I don't keep the flame down on LLLOOWWW
#2571
Race your car!
The high ceiling is the killer.
If you put a hanging space heater in there, put a couple fans on the ceiling to push the heat back down.. that will help a TON.
I'm on the fence with the heat, not sure what I want to do. I think, after looking at the options, once I have the power, insulation and sheetrock done this summer I'll probably go with a hanging space heater, little modine type. Get the local gas company to drop off one of those big propane bottles, put it on a little cement pad whatever. That way I can set a t-stat to say 40, and just crank it up when I'm out there. It's either that or get a pellet stove... one or the other, not sure yet.
I know this, yesterday it was about 10 degrees in my garage.. I went out and thought about putting the front end together for about 5 minutes, then went back in the house
Call me a ***** but that wasn't happening LOL.
#2572
we have a wood burning stove ontop of the little propane one i fire that thing up and it heats the garage allllllll day. the propane one warms it to start then i let the stove keep me cookin for the day. i find myself workin in a tshirt even wen its 2* outside
#2573
Race your car!
Yeah, I thought about doing a little wood stove too. But, I'd have to put it in the corner, and the only way it would heat the whole garage is if I put a fan blowing around it or something to get the air moving around... not sure if I would want to put a fan blowing on it, seems like a bad idea.
Whatever I do.. I'm only putting one in... can't have the garage heat sucking too much car $ up LOL.
#2574
we hav a fan 2' behind the exhaust pipe to blow the heat it sits on a big piece of aluminum hasnt been a problem yet for 2yrs. just some ideas. ima stop talkin bout heat now i feel like im messin up this good thread
#2575
#2576
we had a 40x60 shop that was heated but the 2 stacked 55 gallond drum stove. it worked pretty good.
my uncles shop is 60x100 and has to large hanging gas heaters. it has atleast 18 ft ceilings and is insulated and stays really nice in the winter.
i plan in a small hanging electric heater in my 3 car garage once its all finished.
