Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 06-22-2010, 05:45 PM
  #3161
TJ
TJ's Avatar
Originally Posted by Phil99vette
For 3500 or 5500 I can buy a ton of go fast goodies.
at your level in the game, that amount doesnt buy much, and if it does, it wont make it THAT much faster.
Old 06-22-2010, 06:24 PM
  #3162
fenton06's Avatar
You don't know Phil very well then...
Old 06-22-2010, 06:39 PM
  #3163
7 Second Club
Phil99vette's Avatar
Your joking right? I guess its kinda like the difference between someone like billy glidden and chuck ulsch. Both racers are at the top of their class but glidden makes the dollars quadruple in performance and has proven you dont need a big budget or engine to run with the 525" brad anderson blown hemis. Its all in how you approach it, I'm trying to do the most for the least $$, I could have put the money together for a 632 twin turbo setup but there is more in the combo I have so, why move up when you've got soo much left on the table with the current combo.
*****, most of the guys aren't using more than 60% of what the combos are really worth either its the engine combo isn't right or the chassis isn't setup correctly. **** on our back to back 4.70s there was a minimum of 5-6 areas we could have easily gone faster and the track wasn't even that good. And we're not talking about running the motor on the ragged edge and blowing up every pass, more like maximizing the area under the curve.
Old 06-23-2010, 09:05 AM
  #3164
7 Second Club
ty_ty13's Avatar
4000 in parts is a lot of F'in parts.... now if he was having alot of the work done also then no 4k wont go far.
Old 06-23-2010, 03:24 PM
  #3165
BSmiff's Avatar
I think thats where it is. To the guy that said 5500 dont buy a lot of parts must not have a car or be going very fast. 5500 could be a move up in turbo size, a brand new tranny, or a new set of heads. Not to mention dough for normal maintenance.
Old 06-23-2010, 04:34 PM
  #3166
7 Second Club
I can tell you I spend under $400 in an attempt to take a tenth of the 60'. If it works you'll **** bricks.
Old 06-23-2010, 09:55 PM
  #3167
7 Second Club
ty_ty13's Avatar
does it help power management? what are you guinea pigging now?
Old 06-24-2010, 05:25 AM
  #3168
White.Lightning's Avatar
He is adding a flux capacitor. Don't let anyone know I told you though
Old 06-24-2010, 02:30 PM
  #3169
7 Second Club
Yep, I came up with the idea a couple weeks back and honestly its got to work, the question is how much will it help.
Old 06-24-2010, 03:03 PM
  #3170
7 Second Club
ty_ty13's Avatar
oh, is that where you added the extra waste gate?
Old 06-24-2010, 04:55 PM
  #3171
TJ
TJ's Avatar
that would be me.
that money can buy a lot of parts, but once youve dumped tens of thousands into a car, 3-5000 dollars doesnt go as far as it would if he ran a second slower.
ive been chasing hundreths for years. compared to phil, my car isnt that fast, but ive worked a lot to get where i am with my combo, as has phil.
i was only reffering to going faster, not spending the money on normal maintenance and such.
no need to look too far into the comment.
Old 06-24-2010, 05:31 PM
  #3172
Shawn @ VA Speed's Avatar
maybe-or maybe not.Some things are still a secret
Old 06-24-2010, 05:33 PM
  #3173
7 Second Club
No sir.
Old 06-24-2010, 07:24 PM
  #3174
Broke EF's Avatar
No sir.
Well that isn't a secret any more now is it!?
Sean
Old 06-24-2010, 09:19 PM
  #3175
7 Second Club
Sean
We had to add the wastegate to control the boost in the beams, Some modifications were made to the turbo that no one has done before and it will come up on boost quicker hence the precision stage control and the additional wastegate. I'm kinda surprised no one has tried it before.
Old 06-24-2010, 09:40 PM
  #3176
AChotrod's Avatar
5k over time wont get you much since little things add up fast, but 5k all at once is a lot of $$$$$ in parts!!!
Old 06-26-2010, 11:15 AM
  #3177
7 Second Club
Had to take a couple days to plan how I'm going to finish it...
Old 06-26-2010, 02:50 PM
  #3178
DMH Fabrication's Avatar
After seeing the difference on a 76mm turbo we were testing, it'd be interesting to see what a T6 turbo would do with ball bearings in it.
Old 06-27-2010, 03:14 AM
  #3179
GrahamHill's Avatar
What boost controller are you using?
Old 06-27-2010, 11:00 AM
  #3180
Fireball's Avatar
he using the AMS1000
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
