SFI 25.2 Mustang/LSx build "The Renegade"
#3764
Getting closer, Shawn said we should be good to go by the end of the month which will give us 2 weeks to get the car ready. Marcella is working on the intake. It shouldn't be long now. Shawn is still working on getting the block 100% ready to go from the larger main studs to the keyway lifters. The crank is getting a torrington bearing added to help limit some of the stress to the thrust surface.... Stay tuned!
#3765
#3771
I'm a little perplexed by the smaller turbo... It seems that as slowly as you were already having to bring the boost in, a turbo on the big side of optimum made more sense. Are you feeling that the quicker response of the smaller turbo will help you with some transition point where you want the boost to come in a bit more quickly?
#3772
#3775
I dont know, Shawn & Virginia Speed is one of the biggest Mast Motorsports cylinder head dealers and its one thing if they are being built but its not. They were at Marcellas shop for a hot minute and supposedly they have been ready to ship for the past couple months. Its starting to sound like some BS.
#3776
#3778
Race your car!
It doesn't matter how good the heads are, if they are made from unobtanium, it doesn't make much of a difference.
I'm not sure who's worse, Cary or trying to get castings from Pro-filer. Neither one of them seem to be able to do anything in less then 8 months.
I "thought" this would go away when Mast bought Cary out... nice to see that didn't change anything.... and to think that was "supposed" to be one of the big improvements!
