Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 05-05-2012, 09:02 AM
  #4581
Cam72aro's Avatar
Originally Posted by JL ws-6
Everything does, but going strait to this route would have saved a lot of time, and potentially money
Its funny how people can sit back and say couldve shouldve wouldve. . . Arm chair quarterback.
I can hear this thing on the dyno down here in Texas as we speak, lol.
Old 05-05-2012, 03:18 PM
  #4582
7 Second Club
Phil99vette's Avatar
Made about 10 hits on the dyno today. Each one going alittle farther. Last pull it made 1352rwhp at 15psi, 3.6:1 A/F and conserative timing at this point( I think the timing was 24 degrees or so), the plugs looks like it definitely needs more timing.
First few pulls it was 4.0:1 air/fuel, kept adding fuel and it finally was a nice 3.5:1.
some of the pulls
958-5500rpms-10.2psi
1102-6500rpms-13.5psi
1268-7400rpms-14.2psi
1352-7800rpms-15.1psi
Old 05-05-2012, 05:37 PM
  #4583
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
Congrats, incredible power at that psi. How many gallons of fuel did you go through?
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 05-05-2012, 10:20 PM
  #4584
Race your car!
JL ws-6's Avatar
How did the iat look compared to before with gas and the ic? Better or worse? Power looks to be very good, how much earlier is the tq coming in compared to before, curve look a lot wider? The tq curve improvement, and tq curve improvementis what made my decision to take the route with the bbc, alot wider/ fatter curve and less weather adjustments needed,
Old 05-05-2012, 10:23 PM
  #4585
Race your car!
JL ws-6's Avatar
How did the iat look compared to before with gas and the ic? Better or worse? Power looks to be very good, how much earlier is the tq coming in compared to before, curve look a lot wider? The tq curve improvement, and tq curve improvementis what made my decision to take the route with the bbc, plus the consistancy without adjusting for weather as much, makes for less work. Also are you draining the aluminum cell all thd time or did you go to a plastic one?
Old 05-06-2012, 09:46 AM
  #4586
7 Second Club
The power curve is broader alot of it is because it will make boost faster but the fuel is also helping
IAT before were 50s, now they are 180-195 at 14# of boost
Old 05-06-2012, 10:12 AM
  #4587
Race your car!
JL ws-6's Avatar
Curious what the iat in the intake runner is vs the charge piping after the methanol hits it... I know it's not uncommon to see moisture/ frost show up on the outside of n/a intakes after a run...
Old 05-07-2012, 09:14 AM
  #4588
Fireball's Avatar
yeah...measuring IAT in the charge pipe is pretty much useless when chemical intercooling at the injectors
Old 05-07-2012, 04:14 PM
  #4589
Race your car!
JL ws-6's Avatar
I asked and was hoping a probe made it into one of the runners.... Not sure if anyone has tried that but it would be interesting data to see
Old 05-07-2012, 04:25 PM
  #4590
TheLS1Lover's Avatar
I ♥ this build Phil. I have read all 229 pages 4 times. Will you adopt me?
Old 05-07-2012, 06:08 PM
  #4591
Wnts2Go10O's Avatar
sneak a probe just forward of the injector with its own bung. hop to it phil!
Old 05-07-2012, 07:08 PM
  #4592
Race your car!
JL ws-6's Avatar
Be nice info to have, and track as the power level increases/boost generated heat increases, see at what point the chem. intercooling is no longer effective if it hits that point.
Old 05-08-2012, 06:57 AM
  #4593
Fireball's Avatar
Blown Alky cars (the badass cars just below the fuelers) don't run intercoolers...I'm sure he'll be just fine
Old 05-08-2012, 07:06 AM
  #4594
ks my ss's Avatar
Our pro mod would ice up the injector hat and have condensation on the manifold on hot humid days.
Old 05-08-2012, 08:04 AM
  #4595
Race your car!
JL ws-6's Avatar
No need to explain the benefits, well aware, even with na stuff it's worth it if your rules allow.
Old 05-11-2012, 02:23 PM
  #4596
Wnts2Go10O's Avatar
so are you testing today/this weekend, phil?
Old 05-11-2012, 02:27 PM
  #4597
7 Second Club
Very soon, just got the suspension setup and the wastegate tubes done, just need to find a good track/rental.
Old 05-12-2012, 03:08 PM
  #4598
defbob's Avatar
you mean an MIR rental
Old 05-12-2012, 04:37 PM
  #4599
7 Second Club
I've got a set of Precision 65# injectors I need to sell if anyone knows someone....
Precision 65# injectors $420
Aeromotive Red hex drive fuel pump $450
Jesel belt Distributor drive
Old 05-13-2012, 10:30 AM
  #4600
7 Second Club
Made the decision to switch the MSD 8 box for a Pro Mag 44 Ignition. Its the last piece that I am not 100% happy with. With the right parts it should be a bolt in affair. Going to use an RCD Magneto drive, MSD Mag 44(CW) with the pro cap and get a couple plug wires from firecore to replace the short ones.
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
