SFI 25.2 Mustang/LSx build "The Renegade"
#4701
What about a 555 BBC with twin 4788's on alky? It is incredible how fast this car spools.
Pulls in, lights first light, within 2.5 seconds if not less he has bumped foward into the 2nd light with 9psi of boost.
From what I am told it will make 20psi within the first 120' of the track.
Yeah a 555 with a BBC and 4788s can definitely do it. If the chassis is setup right, most cars can take a 2-2.5psi swing over the first 2 tenths after wheel speed is generated.
#4703
My dad is taking the trans and converter to Chris Esterly of ATI so he can R & R both components to ensure they are perfect. The T/C slip numbers were quite interesting compared to the gas numbers. Essentially the same wheel speed but at 350 lower RPMs due to lower slip.
#4707
It gets on the chip almost like a lightswitch now. At this point I am going to leave it alone and see what happens.
#4711
Finally got around to get a pushbar setup done. Used some stuff I had around the shop and got some few things to complete it. Here is what I got....
Had some 1/4" plate for the base, 1" .125 wall square tubing and some 7/8" .090 for a gusset. Tube is 3/4 .125
Got my ATI Superglide back with a few upgrades I was not expecting. Added a pump to help cool the fluid down between rounds and makes changing fluid in the entire system a breeze. It not takes 5 minutes to change 11 quarts out and completely flush the system with new fluid.
#4712
LS1TECH Sponsor
Keep it hooked up on a pass and it would be a hell of a ride in the cart!!
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
#4715
LS1TECH Sponsor
With the bottom tube configured like it is, it would be a good spot for single wheel if things got high.
I like the push bar set up. How much flex is in it while in use?
__________________
