Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 07-29-2012, 02:36 PM
  #4741
Wnts2Go10O's Avatar
maybe youre making that much more power
Old 07-29-2012, 03:17 PM
  #4742
7 Second Club
Phil99vette's Avatar
I doubt it. We did a couple transbrake tests at 3700rpms and made 5.8 and 9psi. Went to the track and had trouble staging, brakes wouldn't hold(think they need to be bleed again) so we didn't leave with not near as much as before.
Old 07-29-2012, 04:10 PM
  #4743
Coal Mining Director
onfire's Avatar
My bet is it was defective. Which brand?
Old 07-29-2012, 06:49 PM
  #4744
outlawdart's Avatar
Yes I agree. I shouldn't of broke so fast. The ones I have seen will twist bout 1-1 1/2 splines then stay there for a good time before they give up or twist anymore. To check how many splines a shaft is twisted, just lay a straight edge on untwisted splines and count splines to the one that you are aligned on. For the ones wondering what I'm talking about.
Old 07-30-2012, 09:55 PM
  #4745
fknsmshn's Avatar
Is that a bend before the splines, or just an illusion?
Old 08-02-2012, 09:45 PM
  #4746
LS1SSII's Avatar
Have you talked to the mfg of the shaft yet? I wonder if it was never heat treated? I would assume they would want it back for testing. Good luck with it.
Old 08-03-2012, 10:40 AM
  #4747
7 Second Club
The tranny should be back today. The mfg fixed it under warranty and they want me to do some measurements on the block to ensure there was no errors in the machine work process. Mainly they want to ensure the bellhousing is aligned correctly with the crank. They state they have never seen a shaft fail like mine and the last shaft failure was over 4 years ago.
Old 08-03-2012, 01:35 PM
  #4748
Wnts2Go10O's Avatar
Originally Posted by JL ws-6
That would cause it.. that shaft is meant to take alot of twist load, you try to flex it (bend) it's not going to be happy at all.
What a pita that would be if it is the block... hopefully not for your sanity's sake.
i think a lot of people here would collectively break down after watching this build.
Old 08-03-2012, 02:58 PM
  #4749
7 Second Club
I'm going to measure it here shortly. I dont think its the issue.
Old 08-03-2012, 04:24 PM
  #4750
7 Second Club
.002 out of roundness
.0015 out of flatness
Old 08-03-2012, 05:47 PM
  #4751
7 Second Club
The only thing that was questionable was the crank hub adapter, it had just alittle too much play. Got a new one machined/converter matched and its a precision fit now.
Old 08-03-2012, 07:54 PM
  #4752
defbob's Avatar
did you have a Coan hub adapter?
Old 08-06-2012, 08:45 AM
  #4753
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
Phil, if there was an award for resiliency...you win. Was this shaft in there on your previous set up? Just wonder whats different.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 08-10-2012, 07:38 AM
  #4754
fergymoto's Avatar
I've seen some shafts twist a little bit and then be fine for years, never breaking. That's racing... stuff breaks. Even brand new stuff. You better be resilient or you won't last long LOL
Old 08-14-2012, 09:00 PM
  #4755
Cam72aro's Avatar
So.. . . Any testing happening soon? I am having withdrawals.
Old 08-24-2012, 11:19 PM
  #4756
Wnts2Go10O's Avatar
hows the car comin?
Old 08-25-2012, 01:49 PM
  #4757
fknsmshn's Avatar
No word in almost a month! Im starting to worry.
Old 08-25-2012, 08:49 PM
  #4758
Wnts2Go10O's Avatar
cars sold, he quit his job, and moved his whole family to PA to live the Amish life
Old 08-28-2012, 06:36 PM
  #4759
LS1TECH Sponsor
Rumor has it Phil sold the Stang to Nasa and they turned it into a rover. It's been renamed to "Curiosity" and is sitting on Mars....
__________________
Old 08-29-2012, 01:42 AM
  #4760
Wnts2Go10O's Avatar
cant be, curiosity is too slow =p. see, what happened is..
got ya didnt i?
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
