Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 06-12-2008, 05:46 PM
  #741
8 second mod
Noyzee's Avatar
good luck bud. looks great
Old 06-12-2008, 11:57 PM
  #742
7 Second Club
Phil99vette's Avatar
alright...just got home, mostly good news. Ran the car on the gates without the boost controller, boost was right around 13psi.
1st pull was short to make sure everything was working correctly.... Made 750rwhp shutting it off as soon as boost came online.
Made 10 pulls on 13psi
added timing 2-3 degrees per run
Tweaked fuel until it was 13:0 - 0 psi && 11.5 13psi Its got a nice transition
Last pull was not really clean, spun the tires alittle
made ~1100hp from 6000 to 9000, horsepower was flat as a table
13psi, 11.5 A/F, lot of timing
Decided to call it quits since it was getting late.
Overall everyone was happy with the numbers.
Old 06-13-2008, 06:26 AM
  #743
Duffster's Avatar
Schwing! ! !
Old 06-13-2008, 06:48 AM
  #744
Fireball's Avatar
1100 on 13 lbs
Old 06-13-2008, 07:37 AM
  #745
Race your car!
JL ws-6's Avatar
WOW that thing makes some steam huh!
1100 rw in that car, if it's 2800 lbs like you wanted to get it to should be a 8.30 with probably 1/2 the boost you built the car to run with
Old 06-13-2008, 07:47 AM
  #746
summitproducts's Avatar
very nice!!
Old 06-13-2008, 06:41 PM
  #747
gmtechnician's Avatar
im impressed
Old 06-13-2008, 06:43 PM
  #748
87Lt1Monte's Avatar
WOW thats AWSOME
Old 06-13-2008, 07:14 PM
  #749
ls2 bait's Avatar
damn on high boost that car could be a contender in the drag radial class with a 91 on it
Old 06-13-2008, 08:37 PM
  #750
7 Second Club
Where did you get a 91mm from?
Old 06-13-2008, 09:40 PM
  #751
Rogue86's Avatar
Sounds good man, now go put a hurtin' to those radials!
Old 06-13-2008, 10:04 PM
  #752
qwiketz's Avatar
phil, nice numbers. That car should fly.
Earlier in the thread you mentioned that you chose a mustang because things fit together well. What other considerations got you to go with a mustang instead of f body? Was weight a big issue? Both cars seem to hook well with the right parts added on.
Old 06-14-2008, 07:19 AM
  #753
ls2 bait's Avatar
typo sorry
Old 06-14-2008, 08:27 AM
  #754
7 Second Club
I've always liked the mustang body(99-04) better than the camaro. The parts are less expensive and available everywhere.
Old 06-14-2008, 08:29 AM
  #755
7 Second Club
Anyone know how fast 1100 average rwhp gets you with a 1.25 60'?
Old 06-14-2008, 08:37 AM
  #756
Race your car!
JL ws-6's Avatar
1100 with a 1.25 60 foot should be somewhere around 8.4 to 8.1 pass, at least it is with a 3000 lb car. If your car is lighter, then it should be on the faster end of that.
Only bad part is that say it goes 8.25, adding another 100 hp is only gonna get it to 8.15
Stupid physics LOL
Old 06-14-2008, 09:28 AM
  #757
White.Lightning's Avatar
According to my calculator:
2800# race weight
1100 rwhp
nets a 7.953 ET @ 171.38 mph
Sound about right? There wasn't a field for 60'
Old 06-14-2008, 01:56 PM
  #758
RAGENZ28's Avatar
So what's it make @ 20-30 psi
Old 06-14-2008, 02:31 PM
  #759
slow and da curious's Avatar
Default All I Can Say Is.....
AND
Old 06-14-2008, 03:26 PM
  #760
ls2 bait's Avatar
2800# race weight
1100 rwhp
id say thats pretty close depending on how the power comes in. my buddys notchback made 986 rwhp and used to run either 8.10 or 8.20 i forget. that was also a turbo car and weighed around 3k.
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
