Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 09-27-2008, 11:23 AM
  #1241
7 Second Club
Phil99vette's Avatar
Originally Posted by Tiago
Tom's post brings up a good point.
Phil,
have you talked to LME or LMR? Their race car also has a LSX block that has pushed 2500+ HP and got beat on real good, they did a few disassemblies for inspection and everything was looking good. They ran the **** out of that car and it was trapping as high as 193.
Tom's post is a great one. I would like to hear how Tom's bottom end is fairing with the 4" Crank after 50 passes or so @ 8800rpms making 2000hp+. I am not taking anything away from Tom because they do have an awesome program going but..... With the assumption that his block is basically stock with upgraded fasteners and standard machine work, I would be willing to bet that Tom will have problems with his motor also with the above test. You just can't change the blocks design.
There have been a few LSx meltdowns that have not and will not be posted on any public msg board. As far as who I have already talked to, I can't really say. Don't believe everything you hear.
Old 09-27-2008, 01:12 PM
  #1242
JUICED96Z's Avatar
Originally Posted by smokeum99ta
Phil is a great person, theres no way way of calling someone a dick without offending them! Respectfully or not it just shouldn't be said. He's just one person and he can't please everybody at his personal expense just to make some happy.
I said it made him look like a dick, thats all.
You have to have thick skin sometimes in this hobby
Old 09-27-2008, 01:37 PM
  #1243
Outlaw 10.5 Director
FSTR-THANU's Avatar
Originally Posted by Phil99vette
Tom,
I'll send a PM here shortly. I never talked to Briggs. How many passes have you made with the new crank and 8800rpms?
About 40 or so. I would not even try to go past 50 passes without a disassemble and freshen up anyways. At this HP level I like to see everything inspected. We swap out the trans every 4 races for inspection as well. When you are running at this weight and HP it is not even safe to try and run a durability contest.
Tom
Old 09-27-2008, 06:48 PM
  #1244
Coal Mining Director
onfire's Avatar
Originally Posted by Robin L
WHat feedback would you like? They also build my engines. I have posted what we found and what changes that they made in my engine as well as the turbo engine.
Ask and I will get the answers.
Robin
Robin,
I'm running twin 76's on an LSX block street car. So I'm going to be greedy and say they should do another article on that build with more engineering specifics unless it's proprietary (since they sell engines, they might not want to give many details out). Typical stuff like what was the boost curve vs rpm on the 2050 runs, AIT's, timing, etc, etc....why the heck was a billet one off manifold used....did they dyno other manifolds? Results? Would love to see the LS7 manifold dyno'd on that combo. What were the turbo specs? 88mm leaves a lot out......very impressive build to say the least....bring on the data.
Heck, set up a web site photo and fact sheet on that build,,,, it deserves it.
Old 09-28-2008, 12:09 AM
  #1245
1QuickT-A's Avatar
Phil,
We talked to Brian @ LME last week.. He said they had not had any issues at all with the LSX block. He said that they tore down the turbo motor a few different times for inspection and everything looked brand new.
But, that just isn't enough info for me cause I hear from someone else that there have been quite a few guys with LSX blocks busted all to hell in the cylinders and **** like that.
Old 09-28-2008, 12:13 AM
  #1246
1QuickT-A's Avatar
That is your right. Really IMO your goals were very attainable. I am not currently using a billet crankshaft. I am using 1 stage. I use a 4.185 bore. All of the things that you have listed in your build are more conservative than others being discussed here.
I would love to use 2 stages.
Also remember there are people here making suggestions on their experience with other engines. I would seek out builders who have built the high horsepower LSX engines. A lot of testing and development has been done. I know that this valuable to those who have tested and gained this knowledge.
The bore spacing and the additional material on the crankshaft make the BBC a very reliable engine. Like the SBC there are years and years of development and information.
Either way good luck with your build.
Robin
Thanks Robin.. Like I said we were very excited about our future with the LSX stuff we were planning to put together. We were so dissapointed when we heard all these horror stories that we just sat at the shop in total disgust with not much to say about it. Maybe later on if something changes and things with the LSX block start to look up a bit we might go back that route. I will be keeping my LS 408 with two speedtech kits on it though it just won't be in the 98Z race car. Looking for a 4dr Malibu to put it in and make some people look like fools on the skreet!
Old 09-28-2008, 12:17 AM
  #1247
1QuickT-A's Avatar
Originally Posted by 68maro
why only 2 foggers?
Well this 526 BBC went 4.70/80s back in the early 90's in a 2500lb tube'd mustang on just 1 big fogger. We are hoping for 5.20s in my stock suspension fbody. This motor has been sitting for a LONG time, but I'm ordering a new set of aluminum rods next week and freshening it up. Dropped about 100lbs out of the Z today and got a little more to go.
Old 09-28-2008, 08:25 AM
  #1248
LS1Tech Sponsor
Robin L's Avatar
Originally Posted by onfire
Robin,
I will be bolting my engine on Thomson's dyno this morning. I will ask for the informaton.
I know that Performance Division made the manifold. It was made to clear the hood on the Impala SS.
No other manifolds were tested.
Turbos were Turbonetics as the article stated. I'll get the info on the exhaust housings etc.
I will see if Brian will give me a printout of the pulls. Good info there.
Robin
Old 09-28-2008, 08:31 AM
  #1249
onfire's Avatar
Robin
Thanks Robin.
That was a killer build.
Old 09-28-2008, 06:58 PM
  #1250
7 Second Club / STF Veteran
68maro's Avatar
3 will always be faster than 2 even if you spray the same total amount.
Old 09-28-2008, 08:06 PM
  #1251
Shawn @ VA Speed's Avatar
Old 09-28-2008, 08:24 PM
  #1252
68maro's Avatar
ok back on track (somewhat) you all coming to mir oct 10th?
Old 09-29-2008, 08:23 AM
  #1253
7 Second Club
**** no. Shawn is trying to wittle new pistons out of a chunk of aluminum using a fork and knife.
  #1254
7 Second Club
ty_ty13's Avatar
Originally Posted by JUICED96Z
If I remember right you are the one that has like 200 pounds hanging off the back of your car so it will hook..............
and like i said... haul your **** down here and we can run at one of my backwoods tracks.
Old 09-29-2008, 01:07 PM
  #1255
7 Second Club
Man after looking for days I found 2 sets of some 9310 gears that are prefect for my setup. I looked high and low and could not find a set of 9310 gears bigger than 3.40s. Place down in SC had a few sets of old stock that are not currently on the market.
Old gears: 8200 = 192/193
New gears set A: 8200 = 209/211
New gears set B: 8200 = 212/213
So either gear will drop me in the mid to high 7s for 200mph which is where I want to be.
Old 09-29-2008, 02:07 PM
  #1256
7 Second Club
ty_ty13's Avatar
danny miller rear gears has all sorts of weird gear ratios... he makes all the setups for these small tire cars... although here lately i cant find his website... im sure some guys you know probably have his number.
Old 09-29-2008, 02:35 PM
  #1257
xfactor_pitbulls's Avatar
So what powerplant is going to motivate those gears. Have you decided what route you are going yet?
Old 09-29-2008, 03:25 PM
  #1258
7 Second Club
We're going to throw the LSx back together, mock it up on the engine dyno, make 50 pulls @ 2000+hp, tear it down. If we can get it to live we'll throw it back in the Mustang, if not we'll part it out and build a 550+ BBC. My old gears were 3.50s new ones are alittle bigger.
Old 09-29-2008, 04:54 PM
  #1259
LS1Tech Sponsor
Brady's Avatar
Danny Miller didn't have 3:30 or 3:20 pro gears. I finally found a set of 3:20 pro gears out in Cali.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 09-29-2008, 10:28 PM
  #1260
7 Second Club
I was forced to go with a set of 9310 Standard 9" gears. Hopefully the 9310 small pinion will work.
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
