SFI 25.2 Mustang/LSx build "The Renegade"
#1385
pass side was about .010 higher than the drivers side
alot of engine builders dont have the proper equipment to accurately measure deck height.The cnc def helps when it come to accurate measurements.You would be surprised how many blocks i find with the deck height off after they were already decked somewhere else.
#1388
This motor should be about as tough as any LSx on the market. We're using the strongest crank available with probably the best rotating assembly for this setup.
All of the pics I have were labeled confidential but here is one that wasn't marked.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
