6 speed suspension setups, whats everyone got
well i have all winter to decide what im doing to the car, i plan on doing suspension and a rear end, and finish up the motor mods, it will be on the jug next year. car makes 505 at the wheels now, and it will see a big hit.
just curious to what everyone has suspension wise, how its set up, tire size, their power level, and what their 60fts are with the six speed.
vids to go along too would be ****, i love watchin 6 speeds gettin it down the track, i would like to see how the cars leave, how hard you guys are hitting the tires, ect. just want to try to make my car right the first time
i seen in some other threads guys going 1.4s, seen the thread where taner went 1.35 before his clutch decided to end its life down milan dragway. just want to know how you guys are doing it
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Hey man I have 402 make 500 rwhp 6spd I average mid 1.5.Just installed spohn rear drag bar and relocation brackets and getting high 1.4 60's.I have Qua1's all around fronts set at two and rears set at 6.I running bogarts with hossier QTP 27by11.5 on a 15 inch rim.Race weight is right 3400 bud.I have not yey sprayed the car off the line but im sure I can get it to hook off the line and cut the 60' down even more.I have 12 bolt with 410's.
10 Second Moderator
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Not that nobody wants to share, I think the cooler weather has most brains hanging up here. I'm kinda wondering the same and have been taking steps backwards since I put a 1.45 60ft down the same piece of track that taners clutch committed suicide in.
I had a Moser 12 bolt with 4.56 pro gears and Spohn Chromo tq arm, Strange shocks, stock springs and NO blowproof bellhousing. I still had a stock sway bar with a short sleeve on the driver side. 28 12.50 15 ET Streets that were bout done, 15X10 Bogart Force5s, Spek stg4 clutch driving a Liberty preped T-56. H/C 346 with 440 RWHP?
New setup is Moser 9in, spool, 4.56 street gear, BMR extreme CroMo arm, McCloud bell. Same motor, same everything else. Thinking I might move the floor down more so I can push the gas petal down further.
Milan is still open right? one more saturday? Hope the weather holds and lets me run one more trip down there.
Any other thoughts? Not hijacking just want more info on hooking a stick car.
naa, today was last day at milan. no more racing for the year
good to see you guys hitting 1.4 60fts. shows i have a lot to cut off of my 60ft, cause im only hitting mid 1.8s if im lucky riding the clutch out on nittos and stock everything with my 402.
just trying to see what works with everybody for gettin it to hook.
10 Second Moderator
[QUOTE=JDP;8065497]naa, today was last day at milan. no more racing for the year
I called them on Friday 11/2 and the girl I talked to said "next 2 saturdays 11AM to 6PM"
I'll call before I load up though...Maybe US-41 Morocco, Ind on Sunday. Good track prep but somewhat rundown facilities and NO rollbar police.
126
its on stock everything, all the way down the the pads and rotors, lol (gotta change those over winter) i still have a few motor mods to do, it should get the mph a little more, and i need to put a rear end in with a gear for sure, and do the suspension, and i should be running in the 10s decently. then the bottle comes after all of that
umi chassis mount adj. tq arm, umi tubular sfcs, LCAs, KYB 8 way adjustable shocks set on 1 (softest) all the way around. BMR adj panhard bar, stock springs, moser 12 bolt w/ 3.73s M/T ET street radials 275 50 15 @ 22psi, bolt ons, weight reduction. cut some 1.7's, 1.69 was my best so far since ive been back to the track on these tires. its bogging a lil. i need to get out there more!!
1.40 60ft
6.3 ET
car was making aroun 650-680HP on this run.
Bilstein shocks (crazy right?!)
Boxed BMR LCA
BMR lowering springs
BMR Extreme TA
Wolfe Sway Bar
M/T 28x10.5 ET Drags
Moswer 12 bolt 4.10 gears.
http://www.youtube.com/watch?v=0724awWcAHw
6.3 ET
Boxed BMR LCA
BMR Extreme TA
Wolfe Sway Bar
126
Put a good rear end in that thing and leave on the limiter =) that thing will leave.
Heres what I have; Trans, everything that they make for it except g-force gears and proshifted. Clutch, Ram 402/610 (410/602 I forget which way it is) setup. Driveshaft, I went steel with 1350 yokes on both ends. Rear, 9" w/ spool and 35 spline axles. TA, PerformanceAutoFabrication( new sponsor >>>>>>>>). BMR adj. race lca's, sfc's, relocation brackets, and panhard bar. my best 60' is a 1.35 leaving at 6k on 26" et drags.
