Trailer Tie Down
There are a lot of cool ways to do it with a lot of expensive tie down. The right way IMO is to used 4 tie. Two in front and two in back. BUT if you are just going to a track close by one in front one in back should be fine. Go around the axle in the back and try to get the tie down around the K-member in the front.
Brendon
Brendon
LS1Tech Co-Founder
I used two in front, and two in back. I criss-cross the back ones.
Let me add a question, what do folks attach their front straps too? I have been using those factory holes in the subframe and they are elongated a bit. Can I wrap the fronts around the suspension?
Also Xaon tighten the stuff up, and then check it at the first stoplite.
Brendon, I've already got 2 tie downs, And plan on going to pick up a couple more. I'll be driving out to HRP from Rosehill, so I'd like it to be fairly secure for that 65 mile trek each way.
I'm mainly looking for where people attach their straps to and how they attach it to them. Especially up front.
On the back, do you throw the straps around the axle tubes near the pumpkin and then criss cross it over?
"The Drag Racing Director"
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Coach
The Bull
Same here. I usually loop a axle strap through my lower control arms off the k-member though. Something about that factory hole that just doesn't impress me on Michigan roads.
On the back two axle loop straps to two tie downs(you can criss-cross them if you want) On the front I put them threw the K-member(After market K-member
). With the stock K-member you can use hook or criss-cross threw the A-arms.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
If you have the proper hooks, the stock located tie down holes are the best to use, and will give you the most solid tie down.
There are 4 of them on our cars. they are oval shaped, the front is the piece of metal that sticks down right by the front fender screws, it looks like reienforced metal.
The rear holes are also oval, and are located on the frame, just in front of where your lower control arms bolt up to the car.
These holes are so strong, that with the proper hooks, I can tie a car down so tight, that I could hang the car vertical, with no worries of the car coming unhooked.
I haul cars for the big 3, so yes, I have stood some cars vertical.
I have also used the straps wraped around the axle.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I had a heavy duty metal eye welded in the center of the front crossmember. I made a y shaped hardend steel chain sling with a hook in the center. I also have 2 smaller chains with smaller hooks one on each side. I drive the car up reach under the front, hook the large chain to the center eye and the smaller safety chains to the 2 holes in the front lower control arms. I then let car roll back and tie down the rear with axle straps and binder. This is a very quick way to secure the car. i needed it easy because we race at night and securing vehicle at night is tricky. One other trick that I use is that I cable tie my axle strap D rings and leave them on the car at all times. That way no bent brake lines by getting a bit careless. Frank95
"I heard you've also had a couple casualties. Something along the lines of equipment failure?"
Dam it, yes, you would have to metion the equipment failure. I have had chains break on me
But didn't destroy the vehicle. That was on vehicles on the bottom, not any on the top, yet.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
