Reaction time
"The reaction time announced is the time that the vehicle took to move off of the starting line compared to when the last amber bulb lit up. A reaction time of .543 means the vehicle left the line exactly .043 seconds after the green came on (.500 after the last amber plus .043 = .543). And a reaction time of .410 means the vehicle left .080 seconds before the green bulb lit which activated the red light instead…a foul start. A perfect reaction time is .500 seconds. A reaction time over .6 seconds is considered marginal and over .7 is slow."
- http://www.toyotaspeedwayatirwindale...ite/howto.html
Most tracks now measure a perfect light as .000 instead of the .500 you mentioned. And if your running brackets or heads-up, a .100 (.600 in the old format) is late and getting sleepier! Most competitive guys are going .040 or better.
Reaction time has no effect on 1/4 mile time because the et clock doesn't start until the car rolls out of the stage beam. You can run 13.50s with a .015 light or 13.50s with a 2.050 light.
Derek
When I first started I would usually get around .050s which is pretty good, but every once and a while I would have a R/T which was like .150. It completely boggled my mind because I felt I was launching the same.
I found out that I was staging inconsistently, now I can pull off .030s usually every time up there without having to worry at all. The best advice is to just stage as shallow as possible, to where the stage light is almost blinking on and off. Then from there learn how and when to react on the last amber.
Next season is going to be an experience, as I am getting a 3600 stall converter put in, and I have a feeling it is going to screw with my R/Ts.
Derek
To find out if the track uses the .000 light or the .x00 light format, see if they are using LED light or the old incandescent lights. The LED come on faster and (from what I last recall) NHRA suggested using the LED with a .000 light, and incandescent with the old format.
