EPS 226/230 FAST 92/92 Dyno Results Update
#105
Wish you would have had it dyno tuned to see if you got any power gains. I've seen some pick up 3-8rwh with the 85 maf and larger lid. Crappy deal on the fast. Is it repairable?
#106
Please post up the Dyno graph and an idle clip if possible. Interested in Idle quality, sound and lower end torque numbers. Would this be a good cam in an auto car witha 3,000 rpm converter or would you need to go to 3,500 or higher? Really don't want to go higher than 3,000 or so since it will kill gas mileage. Looking for a somewhat mild cam that makes good numbers with the Ls6 heads? Thanks
#108
Sold the 90 and now the new build is going to be a FAST 92/92 and some TEA Stage 2.5 LS6 Heads I'm picking up from a local guy. Both the intake and heads are new in box never ran. Got a great deal on them. I'm porting the intake as well. Hope to reach the 460RWH mark. I'm also thinking about rockers as well but not sure which route to go there being I haven't done my research yet.
#111
You will have pretty much the same setup as mine( your heads are better). It will be interesting to see how compare on the dyno
#112
Its not really strength that your gaining more like safety. The needle bearings are caged in the new Trunions. The old ones are exposed and if a rocker were to break apart the bearings would go everywhere in your motor. The stock rockers are designed very well and are very lightweight where it counts. I changed my own out in about 30 minutes very easy to do. They run about $130 as compared to Yella Terra's $479 ish.
#113
The only benefit is strength. I was going to use Harland Sharps on my car but Geoff talked me into running stock rockers with the upgraded trunion.
#114
What kind of gas is going thru her?
Seems like at the rate you're going, eventually you will be adding even more go fast parts in the future, why max out the stockers now when you could have some bigger ones ready to go for any other "mods" down the line?
If money is tight tho, then i'd run the stock ones until you can find something a little bigger in the F/s section or local like with the fast92.
Only reason I ask about fuel is because if goin corn, you'll def need bigger injectors or if you are going to run race gas frequently too.
Good luck with the goals, car looks niice, I sorta like silver...
oh and agreed with others about the trunions upgrade, anything under 1000hp or hyd cam and the rollers aren't necessary really.
#119
Get some ls2 lifter trays. They are much sturdier than the stock ls1's and will not let the lifter turn out of alignment. You need 2 per side and each one is like $8. So $32 for insurance ain't to bad if you ask me. Whatever the case is you need to check for proper length pushrod, preload, and ptv no matter what. Ws6store has both the lifter trays and comp cams trunions upgrade.
