Highest Cam Only through unlocked stall?
Old Sep 24, 2012 | 09:16 PM
Sales@Tick's Avatar
Default Highest Cam Only through unlocked stall?
First I guess you could say it isn't "technically" cam-only since it has a Fast92 but this is what I did tonight...
Spent about an hour and a half dialing the fuel curve after sending the converter off to be tightened for the upcoming thrashing this stock bottom end is going to receive via a lot of nitrous very soon.
This is with a 239/247 .624/.624 110lsa installed straight up, Fast 92, 96mm tb, ARH 1x7/8" with 6-8" extensions off headers and Vibrant 3"x5" mufflers.
Unlocked TH400 FTI 9" stall converter and 20psi of air in the tires, and yes 20psi I didn't pump them up to try and inflate the numbers. I just wanted to get the motor dialed in as best as possible making the most power it can before I spray it. This was with 27* total timing also.
BTW the numbers are 423/382 as I realize my scanner didn't get the best resolution.
Old Sep 24, 2012 | 09:28 PM
BAIN's Avatar
What size stall? What rear? What gear?
Old Sep 24, 2012 | 09:35 PM
Sales@Tick's Avatar
It's a custom FTI 9" stalls to 4200ish on 27* timing on the transbrake with no two step rpm set and flashes 4600 and locks up around 4800 judging by the graph. Old stall would go 4700-4800 on 27* and flash 4900-5000 lock up around 5200. This is all on motor as the converter is a nitrous stall.
12 bolt rear with a spool and 4.11's.
Old Sep 25, 2012 | 11:15 PM
chrs1313's Avatar
Me like the cam
Old Sep 26, 2012 | 08:58 AM
Sales@Tick's Avatar
Originally Posted by chrs1313
Me like the cam
I figured you would like that Chris.
Old Sep 26, 2012 | 07:00 PM
BAIN's Avatar
I'm confused I guess. You said unlocked stall in the first post then in the second post you said lockup around 5200?
Old Sep 26, 2012 | 08:42 PM
Sales@Tick's Avatar
Right, flash and lock-up to me are two different things.
Flash is where the rpm's jump before the car moves off the line, lock-up is when the car starts to accelerate hard normally 200-400rpm after the converter flashes.
I refer to "lockup" as where the converter begins to couple efficiently and starts to pull.
Old Oct 1, 2012 | 01:58 PM
IllusionalTA's Avatar
Old Oct 2, 2012 | 08:19 AM
Sales@Tick's Avatar
Originally Posted by IllusionalTA
Trouble maker...
Old Oct 2, 2012 | 08:25 AM
Trouble maker...
Never that
Old Oct 2, 2012 | 08:50 AM
thunderstruck507's Avatar
When I hear the term lock up in reference to an automatic transmission, I instantly and only think of engaging the electronic lock up clutches in the converter.
Old Oct 2, 2012 | 09:35 AM
While I agree, lock up is normally associated with the clutch in 60e's, it is however negated by the mention. Of a th400.. To me it read fine..
Old Oct 18, 2012 | 01:56 PM
Sales@Tick's Avatar
Here is what the curve ended up looking like after I completely dialed the fuel curve in and got rid of that dip in the graph.
Here is what it looked like with the old N/A 5900 stall in it and without the 4" intake and air bell in the bumper.
Old Oct 18, 2012 | 02:30 PM
What converter in now?
Old Oct 18, 2012 | 02:58 PM
Sales@Tick's Avatar
It's the same 9" core it has just been re-stalled.
Old Oct 18, 2012 | 03:01 PM
Sweet,
Old Oct 26, 2012 | 07:44 PM
BottleFedZ346's Avatar
Nice #'s Martin!
Old Oct 26, 2012 | 09:08 PM
Sales@Tick's Avatar
Thanks Brandun!
I will have nitrous numbers tomorrow!
Old Oct 27, 2012 | 01:27 AM
AINT SKEERED's Avatar
Nice looking set up . Close to what I will have in my s10. Except it's a 238/250 110 Lsa 106 cl and super vic intake and 950 holly
Old Oct 27, 2012 | 06:06 AM
Sales@Tick's Avatar
I like that cam who spec'd it?
