Dyno results: 370 c.i.
Finally got the car on the dyno yesterday after the new engine was broken in.
LQ4 block, 4.030 bore
Diamond -2cc pistons
Eagle 6.100 rods
stock GM crank
ported FAST 90
PRC 5.3 heads
11.5:1
Car has a TDP T56, 9 inch and 4.30 gears.
Car made 462/412 in 73° weather.
Ditching the y pipe and cutout for duals and dumps in hopes of getting that extra power to the ground. No dyno sheet at the moment. Any comments or opinions welcome.
Eagle 6.100 rods
stock GM crank
ported FAST 90
PRC 5.3 heads
11.5:1
Numbers are low??? I didn't think so. I gained 100 horses and almost 90 lbft from the ls1 with an MS3 cam. And while dyno #'s are cool to talk about, I'm more concerned about e/T's.
yeah... small cam
I agree completely on the heads. I was thinking about the PRC 237's next year. I'm going to run this setup this coming season and see what all I can get out of it first.
Its a process. Trial an error, and improvement over time. I plan on changing to a single plane intake too at some point. Just trying to get all I can out of 370 inches before I have to upgrade.
What y-pipe do you have ?
I think I could have gained more power, but dyno looks like I was getting valve float...Springs had alot of time on them and have seen 8,000 rpms several tims
check these y-pipe results out
https://ls1tech.com/forums/generatio...er-y-pipe.html
