Cam Only Dyno Thread
Old Apr 13, 2017 | 11:45 AM
  #541
sscamaroburn02's Avatar
00 Camaro SS 62k miles 6 speed. TSP 228/232 600/600 112 on stock heads with ls6 intake. TSP 1 7/8 headers and ORY. Flowmaster Catback. UDP. LID. stock clutch and rear. Made 407/382
Old Apr 13, 2017 | 07:30 PM
  #542
WS6 #3392's Avatar
Kooks 1 7/8 LT, Kooks TD, SLP Lid, BTR LS3 Supercharger Cam. Lost 21 hp and 25 tq through the Strange S60 rear end.
This is the copy that Jessie sent me. You can see the before and after dyno numbers with the BTR cam.
Old May 29, 2017 | 01:10 PM
  #543
camaroman08's Avatar
99 Camaro SS auto with 164k miles. Pacesetter longtube headers, tsp True duals dumped at the axle, Yank 4000SS converter, SLP Lid, LS6 intake, stock 853 heads (as far as I know they are stock), Tick Performance SNS Stage 3 Cam 235/243 .630/.610 111 LSA. Made 415/407 through the stock 10 bolt and 4l60e. I'm very pleased with the results. Cam Installation and tuning was done by Adam at Aquadale Speed Shop in Norwood, NC. The car has awesome drive-ability and a nasty lope. Excited to see what it'll run in the 1/8, barring the trans and rear end hold. Traction will probably also be an issue as I'm on Nitto 555's, not the drag radials.
Old Jul 23, 2017 | 05:34 AM
  #544
ls1 trex's Avatar
ls1 stock bottom end/4l60e/prc 5.3 2.5/fast 102/231-239 113
466hp/460tq
Old Jul 24, 2017 | 06:28 AM
  #545
466hp/460tq
That torque # is impressive. Can you post the dyno sheet? I'd like to see the curve. Thanks.
Old Jan 14, 2018 | 01:40 AM
  #546
R3d Zeppelin's Avatar
98 z28 m6.
Comp cam.
stock ls1 intake.
806 heads.
Tsp long tubes and exhaust, at the time stock 10 bolt and stock gear. 405rwhp 403.5tq Why did it make such good power with garbage heads and stock intake?.. I'm very curious.
Old Jan 14, 2018 | 09:58 AM
  #547
Originally Posted by R3d Zeppelin
98 z28 m6.
Comp cam.
stock ls1 intake.
806 heads.
Generous dyno??
Old Jan 14, 2018 | 12:08 PM
  #548
Basco's Avatar
Old car:
2002 13k original miles stock LS1
1 7/8 TSP headers and ORY
SLP dual-dual catbak
BTR stage 2 ls1 cam kit
SLP lid
FTI 3200 rpm converter
Everything else stock
Sae corrected 386rwhp/375tq
Tuned by Rodney Booth
Still collecting parts for my new stock bottom end ls1 build.
Old Jan 15, 2018 | 10:40 AM
  #549
Default Twice?
Twice? The guy I bought it from had it on a dyno, and then lethal performance and dyno Inc. Tuned it for me. Both dynos read over 400 on tq and rwhp.
Old Jan 15, 2018 | 11:25 AM
  #550
You are fortunate! You likely just have everything dialed in right, and it all worked together for great numbers! Congrats!
Of course you do not say WHICH Comp you have......
Old Mar 9, 2018 | 01:10 AM
  #551
Mikeypooh1's Avatar
I just want to post my numbers. 437hp @6000RPM and 435.8ft-lbs @4500RPM
Stock Engine, 241 heads, 233/239 TSP cam, FAST 92, 92mm TB, eBay LTH, SLP cat back,
Old Mar 9, 2018 | 01:15 PM
  #552
stock heads? those numbers are crazy high! Whats your secret?!!
Old Mar 9, 2018 | 08:16 PM
  #553
Mikeypooh1's Avatar
Stock heads but it might help that I have no PS, AC. I only have alternator and a fresh rebuild. That’s about it. Tuner did the rest.
Old Mar 11, 2018 | 09:09 PM
  #554
Must be a beast with no PS
Old Mar 11, 2018 | 11:34 PM
  #555
big hammer's Avatar
The record is 471
Old Mar 13, 2018 | 12:06 AM
  #556
Mikeypooh1's Avatar
Driving with no PS is actually not to bad, and power is awesome, now all I am going to do is start working on suspension and tires. I should have done that first.
Old Feb 13, 2019 | 08:50 PM
  #557
Brendyn G's Avatar
99 z28 70k A4
TSP 224/228 112 LSA
Pacesetter longtubes
rods and springs
Speed engineering true duals and SLP lid
Everything else is stock Ls1
400whp on a mustang dyno
Old Feb 14, 2019 | 01:13 PM
  #558
sokr915's Avatar
2000 ws6
Speed Engineering 1 7/8 to Catted true dual
Streetsweeper HT (228/232)
LS6 Intake
Potz Ported TB
Old Feb 14, 2019 | 09:51 PM
  #559
Mikeypooh1's Avatar
Originally Posted by sokr915
2000 ws6
LS6 Intake
Potz Ported TB
Good numbers.
Old Apr 30, 2019 | 11:34 PM
  #560
Nasty_Z28's Avatar
Originally Posted by ajzcamaro
2002 Z28
6 speed manual
75,000 miles
TSP MS4 cam (239/242 Duration, .649/.609 LIft, 112 LSA)
TSP hardened 7.4 push rods
TSP .650 dual valve springs
TSP titanium locks and retainers
Pacesetter long tube headers
Pacesetter off road y-pipe
Magnaflow 3 inch cat-back
SLP lid w/ K&N air filter
SLP smooth bellow
LS6 MAF
Ported and polished throttle body
LS6 intake
LS6 fuel injectors
Racetronix 255 fuel pump
NGK TR55 plugs
HP tuners
Stock 10 bolt w/ 3.73's and Lingenfelter diff cover/girdle
LS7 clutch
Car put down 436 rwhp and 400 ft/lbs tq on a dynojet.
Any times on your car?
