Cam Only Dyno Thread
Old Aug 24, 2012 | 10:48 AM
  #501
MeMz's Avatar
^got the graph on that? That's really impressive numbers for a cam that size
Old Aug 26, 2012 | 04:38 PM
  #502
KFC_Or_Bust's Avatar
Finally got my car tuned last month. Made 418/390 on a Dynapack hub dyno. I had a bad o2 sensor on the drivers side, fixing that and going back for a retune once I throw my new parts on. Apparently 418whp is the highest he's dynoed on a cam only LS1, 8whp more than a Trex. =D
.610/.614 242/246 110 lsa cam
Patriot Gold Dual Valve Springs
7.4" Hardened Rods
QTP Long Tubes
Off Road Y-Pipe
SLP Loudmouth 2 Catback
Stock 853 heads, LS1 intake and TB. Ported 243s, Fast 92 and 92 TB waiting to go on.
Old Sep 4, 2012 | 08:16 PM
  #503
2006cory's Avatar
212/218 557/563 115
3 angle valve job on stock heads
Pac racing spring .600/7.4 crome molly pushrods
K&n intake pacesetter long tubes x pipe there 2 40 flowmasters
Built 4l60e 3500 ptc stall
Posi track with 3.73s
324rwhp/364 rwtq on 265/35/22
Old Sep 20, 2012 | 10:40 PM
  #504
wg871's Avatar
I'll post mine up since it's not a very common cam.
RPM5 238/242 589/612 114+4
TH350 w Yank 4000
Fast 90/90, 85mm Maf, Powerbond 25%, Hedman Torkstep Longtubes, SLP lid
395rwhp
Old Dec 9, 2012 | 11:55 AM
  #505
theC5Vette's Avatar
Comp Cam (224/224) w/stock converter
Kooks 1 7/8" x 3" LTs
kooks O/R Y-pipe 3" x 3"
3" Borla
MTI Lid
160 Thermostat
Powerbond UD pulley
NGK TR55s
MSD Spark Plug wires
HP Tuners Tune
Stock converter works beautifully. The shop's tune is fantastic.
Old Dec 9, 2012 | 08:28 PM
  #506
Sales@Tick's Avatar
Didn't even know this thread existed...here's my set-up:
346 stock bottom end with Katech rod bolts
Custom 239/247 .624"/.624" 110+0 camshaft
Stock 241 heads 10.33:1 static compression 7.58:1 dynamic compression
Vengeance Ported Fast 92 with 96mm NW TB
ARH 1x7/8" headers 10" extensions off each collector with 3"x5" Vibrant mufflers
Unlocked TH400 4600rpm 9" FTI stall
12 bolt w/ spool and 4.10 gears
275/60 Hoosier Drag Radials@19psi
Pulls had 12.9-13.1 AFR and 27* timing from 2800rpm to red line
Old Jan 13, 2013 | 02:24 AM
  #507
2000XJblue's Avatar
magic stick 4 cam
bbk ssi intake
pacesetter headers
granatelli maf that is jacked up. need to buy a new one
th350 3600 supposedly converter.
4.10 gears with 275/60/15 mickey thompsons.
stock heads with dual valve springs
rpm tuned it on jan 4 at 384hp and 344tq.
jan 5 in fayetteville nc first pass it went 11.79@116 7.56@93 in the 1/8th.
i think it has some more in it. 60ft was only 1.79 and it spun 7-8ft. tire pressure was set to 20.
Old Apr 25, 2013 | 06:45 AM
  #508
Schweet97Z's Avatar
Stock Bottom End
Stock untouched 853's
Unported Fast 92/92
TSP 100mm MAF
FTP 104 Lid
LG Motorsports G5x4
Longtubes
Borla
9" Rear
434 rwhp / 405 rwtq
Old Apr 25, 2013 | 07:18 AM
  #509
Jason78's Avatar
00 ws6 m6 96k mile stock bottom end, trex, stock heads, ls6 intake, lt's, magnaflow catback, cutout but closed, 17x11 zr1 dd wheels with 315-35 tires, 404 rwhp 379.6 rwtq, mustang dyno
Old Apr 26, 2013 | 03:17 PM
  #510
VIPERBLUELX's Avatar
01 SS, 156K mile engine, EPS 230/230 .600 .600 113+4 cam, BBK longtubes and Y-pipe, Magnaflow catback, 3500 stall, 346rwhp unlocked with the converter slipping. I've got a PTC on the way.
Old Jun 12, 2013 | 02:43 PM
  #511
hglenn's Avatar
anyone running a 233/234, 617, 112 cam
Old Jun 12, 2013 | 04:26 PM
  #512
slvr T/A's Avatar
224/228 .581/.588 on a 112
BBK SSI intake with stock TB/MAF
BBK long tubes o/r Y and 3" cutout open
U/D pulley
Made 390/380 a few weeks ago.
Old Sep 12, 2013 | 09:10 PM
  #513
nismoautoxr's Avatar
95 240 sx with 04 GTO LS1 with a T56 all stock except custom grind comp cam and springs 230/232 on 114 LSA running megasquirt3/3x management full sequential fuel and spark and speed density algorithm. 3100# car with me in it on 255/40 17 RS3 hankooks. 4:10 gear . Full interior daily driver with working A/C. good idle at 800 but noticeble cam lope . Very good driveability above 1300 RPM in 6th gear for a cammed up 3100# car IMHO
Blowing through stock cast iron manifolds (LH GTO and RH camaro)and a dual 2.25 into a single 3 inch dynomax muffler.
376 HP@6200 and 351 TQ@5000 dynojet dyno
Interesting enough the HP was still on an upward climb at the rev limiter but decided not to up it given the motor is a 100K salvage yard pullout.
Old Dec 5, 2013 | 02:47 AM
  #514
ajzcamaro's Avatar
2002 Z28
6 speed manual
75,000 miles
TSP MS4 cam (239/242 Duration, .649/.609 LIft, 112 LSA)
TSP hardened 7.4 push rods
TSP .650 dual valve springs
TSP titanium locks and retainers
Pacesetter long tube headers
Pacesetter off road y-pipe
Magnaflow 3 inch cat-back
SLP lid w/ K&N air filter
SLP smooth bellow
LS6 MAF
Ported and polished throttle body
LS6 intake
LS6 fuel injectors
Racetronix 255 fuel pump
NGK TR55 plugs
HP tuners
Stock 10 bolt w/ 3.73's and Lingenfelter diff cover/girdle
LS7 clutch
Car put down 436 rwhp and 400 ft/lbs tq on a dynojet.
Old Dec 26, 2013 | 11:21 AM
  #515
stockz's Avatar
My ride has a Voodoo cam
232/238 .599/.601
Fast 90
Holley 90 tb
Pacesetter stainless headers
Magna-flow CB
Y-pipe
stock 6.0l heads with ls1 valves ( not sure if the 6.0 are deff)
6.0l block
Lid
Makes 406/396 on motor rwhp on a Mustang dyno
Outran a F430 on the motor de-tuned @ Ga 1/2 Mile shootout.
Old May 12, 2014 | 09:06 PM
  #516
02'Andy's Avatar
Got my car back recently after getting a cam swap, so I'll post up my new numbers. It's a custom cam that's going to be used for a turbo build down the road, but retained enough N/A characteristics to be useful for me right now.
230/235 .609"/.610" 114 LSA cam
.660" Dual Valve Springs
Hardened .80 wall pushrods
Trunion bearing kit on stock rockers
Also added a melling high volume oil pump. The car already had full bolt-on's and a VRD ported FAST 92 with a NW 92 TB.
Put down 413/368, should have new track times in a few days.
Here's the graphs, the dyno had a hiccup on the 413/368 run.
Old Oct 1, 2014 | 09:22 AM
  #517
Mercracing's Avatar
New to the forum so ill share my numbers.
2006 LS2 CTSV
6 speed manual t56
60,000 miles
SNL VX cam specs unknown
BTR 650 lift springs
magnaflow 2 1/2 inch no cats
K&N filter
power bond under drive balancer
Willie Figaro tune
Car made 459 rwhp and 413 ft/lbs tq on a dyno jet
Old Nov 18, 2014 | 05:54 PM
  #518
Sail Hatan's Avatar
old car: 2002 t/a, 231/235 cam, tsp long tubes, full length duals, ported tb, lid, etc tuned made 382/366 through unlocked 3800 stall.
new car: 2000 camaro 231/235 cam, dynatech headers,dumped h pipe with bullets, ls6 intake, ported tb. lid, made 406/380
Old May 13, 2015 | 11:50 PM
  #519
BoricuaHec01's Avatar
Formally Simplɘ Jack
Got my car back today from getting a cam package and tuning, I went with the S15 231/237 .589 .595 112, other mods are in sig. Really impressed with the numbers.....
Old Jun 1, 2015 | 01:48 PM
  #520
2MCHPWR's Avatar
1998 formula ws6 1LE.
Cam - 228/232, 114LSA, .588/.595 comp cams, dual valve springs, titanium retainers
stock 241 heads
alum flywheel
92mm FAST intake
92mm NW Tbody
85mm c5z06 MAF
98mm FTP lid
SSRA
stock 28 lbs injectors - hit 99% duty cycle
headers - speed engineering 1 7/8", TSP 3" off-road Y, stock ws6 muffler single on the left
403 hp and 370 torque
Waiting to retune with 36 injectors
